以前用的 idf4.4 编译的,今天升级5.0 后出现这样的问题:
OJECT_VER. -- Building ESP-IDF components for target esp32c3 -- Project sdkconfig file H:/esp32test/esp32c3_test/template-app/sdkconfig CMake Error at H:/esp-idf/tools/cmake/crosstool_version_check.cmake:37 (message): Toolchain: C:/Users/xy/.espressif/tools/riscv32-esp-elf/1.24.0.123_64eb9ff-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe, crosstool-ng version 1.24.0.123_64eb9ff doesn't match supported version esp-2021r2-patch3 Please try to run 'idf.py fullclean' to solve it quickly. Check Getting Started documentation if the error continues. You can override this error and proceed with build by defining the IDF_MAINTAINER environment variable. Call Stack (most recent call first): H:/esp-idf/components/esp_common/project_include.cmake:7 (crosstool_version_check) H:/esp-idf/tools/cmake/build.cmake:324 (include) H:/esp-idf/tools/cmake/build.cmake:537 (__build_process_project_includes) H:/esp-idf/tools/cmake/project.cmake:422 (idf_build_process) CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! See also "H:/esp32test/esp32c3_test/template-app/build/CMakeFiles/CMakeOutput.log". See also "H:/esp32test/esp32c3_test/template-app/build/CMakeFiles/CMakeError.log". cmake failed with exit code 1 |
211个成员聚集在这个小组
加入小组514 浏览 1 评论
2181 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
432浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
221浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
244浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
651浏览 2评论
317浏览 2评论
GMT+8, 2025-4-2 07:26 , Processed in 0.757504 second(s), Total 72, Slave 57 queries .
