使用vs code espressif插件编译v4.4版本sdk报错,输出如下
> Executing task: cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 .. < -- Could NOT find Git (missing: GIT_EXECUTABLE) CMake Warning at D:/esp/esp-idf-master/tools/cmake/git_submodules.cmake:4 (message): Git executable was not found. Git submodule checks will not be executed. If you have any build issues at all, start by adding git executable to the PATH and rerun cmake to not see this warning again. Call Stack (most recent call first): D:/esp/esp-idf-master/tools/cmake/idf.cmake:39 (include) D:/esp/esp-idf-master/tools/cmake/project.cmake:12 (include) CMakeLists.txt:5 (include) -- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: D:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32 -- Project sdkconfig file D:/MyProject/ESP32/hello/hello_world/sdkconfig -- Looking for sys/types.h -- Looking for sys/types.h - found -- Looking for stdint.h -- Looking for stdint.h - found -- Looking for stddef.h -- Looking for stddef.h - found -- Check size of time_t -- Check size of time_t - done CMake Error at D:/esp/esp-idf-master/tools/cmake/component.cmake:304 (message): Include directory 'D:/esp/esp-idf-master/components/mbedtls/mbedtls/include' is not a directory. Call Stack (most recent call first): D:/esp/esp-idf-master/tools/cmake/component.cmake:477 (__component_add_include_dirs) D:/esp/esp-idf-master/components/mbedtls/CMakeLists.txt:10 (idf_component_register) -- Configuring incomplete, errors occurred! See also "D:/MyProject/ESP32/hello/hello_world/build/CMakeFiles/CMakeOutput.log". 终端进程“C:WINDOWSSystem32WindowsPowerShellv1.0powershell.exe -Command cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 ..”已终止,退出代码: 1。 |
172个成员聚集在这个小组
加入小组430 浏览 1 评论
1293 浏览 1 评论
598浏览 6评论
495浏览 5评论
481浏览 5评论
476浏览 4评论
462浏览 4评论
GMT+8, 2025-1-12 07:19 , Processed in 0.544933 second(s), Total 40, Slave 35 queries .
