我按照说明操作,VSCODE 无法使用该库:
https ://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/system.html#_CPPv411esp_restartv Code: Select all [Starting] Analyzing sketch 'TESTTEST.ino' [Warning] Output path is not specified. Unable to reuse previously compiled files. Build will be slower. See README. Loading configuration... Initializing packages... Skipping contributed index file C:UsersAdministratorAppDataLocalArduino15master.zip, parsing error occured: com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'PK': was expecting ('true', 'false' or 'null') at [Source: (FileInputStream); line: 1, column: 6] Skipping contributed index file C:UsersAdministratorAppDataLocalArduino15master.zip, parsing error occured: com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'PK': was expecting ('true', 'false' or 'null') at [Source: (FileInputStream); line: 1, column: 6] Preparing development board... Verifying... TEST:6:25: fatal error: periph_ctrl.h: No such file or directory compilation terminated. exit status 1 [Warning] Failed to generate IntelliSense configuration. [Error] Analyzing sketch 'TESTTEST.ino': Exit with code=1 命令没作用Arduino: Rebuild IntelliSense Configuration 如何为 ESP32 实现软重启? |
192个成员聚集在这个小组
加入小组472 浏览 1 评论
1655 浏览 2 评论
647浏览 6评论
536浏览 5评论
516浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-24 15:59 , Processed in 0.670807 second(s), Total 40, Slave 35 queries .
