通过esp-idf-tools-setup-online的工具安装开发环境,重新安装了几次还是报错:
Running cmake in directory g:esp32esp32-s3-86-panelcodeesp32-rgb-4inchexampleslvgl_demobuild Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=1 g:esp32esp32-s3-86-panelcodeesp32-rgb-4inchexampleslvgl_demo"... -- Found Git: D:/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1") fatal: no submodule mapping found in .gitmodules for path 'components/bt/controller/lib_esp32h2/esp32h2-bt-lib' -- ccache will be used for faster recompilation -- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: D:/Espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/Espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/Espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32s3 -- Project sdkconfig file G:/ESP32/ESP32-S3-86-Panel/code/ESP32-RGB-4inch/examples/lvgl_demo/sdkconfig -- Looking for sys/types.h -- Looking for sys/types.h - found -- Looking for stdint.h -- Looking for stdint.h - found -- Looking for stddef.h -- Looking for stddef.h - found -- Check size of time_t -- Check size of time_t - done -- Found Python3: D:/Espressif/python_env/idf5.0_py3.8_env/Scripts/python.exe (found version "3.8.7") found components: Interpreter -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success CMake Error at D:/Espressif/frameworks/esp-idf-master/components/mbedtls/mbedtls/CMakeLists.txt:148 (message): Could not create symbolic link for: D:Espressifframeworksesp-idf-mastercomponentsmbedtlsmbedtlslibraryerror.c --> 系统无法将文件移到不同的磁盘驱动器。 Call Stack (most recent call first): D:/Espressif/frameworks/esp-idf-master/components/mbedtls/mbedtls/library/CMakeLists.txt:162 (link_to_source) -- Configuring incomplete, errors occurred! |
179个成员聚集在这个小组
加入小组441 浏览 1 评论
1419 浏览 1 评论
610浏览 6评论
506浏览 5评论
487浏览 5评论
490浏览 4评论
474浏览 4评论
GMT+8, 2025-1-26 14:58 , Processed in 0.692133 second(s), Total 42, Slave 37 queries .
