ble_hs_hci_cmd_send at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_hci_cmd.c:89 (discriminator 15)
ble_hs_hci_cmd_send_buf at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_hci_cmd.c:134 ble_hs_flow_tx_num_comp_pkts at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_flow.c:95 ble_hs_flow_event_cb at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_flow.c:116 ble_npl_event_run at D:/ESP-IDF/components/bt/host/nimble/nimble/porting/npl/freertos/include/nimble/nimble_npl_os.h:125 (inlined by) nimble_port_run at D:/ESP-IDF/components/bt/host/nimble/nimble/porting/nimble/src/nimble_port.c:78 mesh_host_task at d:cwqcodelightbuild/../components/ble_light/src/bt_init.c:160 vPortTaskWrapper at D:/ESP-IDF/components/freertos/port/xtensa/port.c:168 //--------------------------------------------------------------------------------------------------------------------------- ble_hs_hci_cmd_send at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_hci_cmd.c:113 ble_hs_hci_cmd_send_buf at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_hci_cmd.c:139 ble_hs_hci_cmd_tx at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_hs_hci.c:304 ble_gap_adv_set_data at D:/ESP-IDF/components/bt/host/nimble/nimble/nimble/host/src/ble_gap.c:2649 bt_le_adv_start at D:/ESP-IDF/components/bt/esp_ble_mesh/mesh_core/nimble_host/mesh_bearer_adapt.c:777 adv_send at D:/ESP-IDF/components/bt/esp_ble_mesh/mesh_core/adv.c:180 (inlined by) adv_thread at D:/ESP-IDF/components/bt/esp_ble_mesh/mesh_core/adv.c:318 vPortTaskWrapper at D:/ESP-IDF/components/freertos/port/xtensa/port.c:168 ------------------------------------------------------------------------------------------------------------------- 请教一下大佬 我们使用mesh加手机ble与esp32通信时遇到一个死机问题 手机快速和设备通信的同时如果往mesh网络发送数据大概率会导致死机 经过分析后发现是 ble_hs_hci_cmd_send 函数重入了 (mesh_host_task ,adv_send)此函数调用 ble_hci_trans_buf_alloc(BLE_HCI_TRANS_BUF_CMD) 申请内存 但是此内存池大小被初始化成了 1 导致第二次申请失败 从而引发死机 请教一下有没有大佬遇到过这种情况 需要怎么解决 |
166个成员聚集在这个小组
加入小组1143 浏览 1 评论
582浏览 6评论
480浏览 5评论
465浏览 5评论
466浏览 4评论
441浏览 4评论
GMT+8, 2024-12-23 18:42 , Processed in 0.835831 second(s), Total 70, Slave 54 queries .
