ESP-IDF v4.4的LCD外设lvgl例程直接build会报错(其他例程能够正常编译和烧录)
使用的是ESP32S2和VScode集成IDE,报错主要内容如下: CMake Warning at E:/Softwares/ESP/Container/esp-idf/tools/cmake/build.cmake:482 (message): "idf_component.yml" file was found for components: E:/ESP32_Projects/S2_demo/lvgl/main However, the component manager is not enabled. Call Stack (most recent call first): E:/Softwares/ESP/Container/esp-idf/tools/cmake/project.cmake:378 (idf_build_process) CMakeLists.txt:4 (project) -- Could NOT find Perl (missing: PERL_EXECUTABLE) CMake Error at CMakeLists.txt:9 (target_compile_options): Cannot specify compile options for target "CONFIG_IDF_CMAKE" which is not built by this project. |
211个成员聚集在这个小组
加入小组514 浏览 1 评论
2181 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
432浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
221浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
244浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
651浏览 2评论
317浏览 2评论
GMT+8, 2025-4-2 06:44 , Processed in 0.678369 second(s), Total 43, Slave 36 queries .
