硬件版本:ESP32-LyraT-Mini V1.2
软件版本:esp-idf : release V4.4 esp-adf : https://github.com/espressif/esp-adf.git 该链接的master版本 操作系统:win10 IDE:vscode 问题描述:在该环境下运行pipeline_raw_http例程始终没有联网过程,设备获取不到IP地址,log如下: I (27) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (27) boot: compile time 14:23:05 I (27) boot: chip revision: 3 I (30) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (38) boot.esp32: SPI Speed : 40MHz I (42) boot.esp32: SPI Mode : DIO I (47) boot.esp32: SPI Flash Size : 8MB I (51) boot: Enabling RNG early entropy source... I (57) boot: Partition Table: I (60) boot: ## Label Usage Type ST Offset Length I (68) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (75) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (82) boot: 2 factory factory app 00 00 00010000 00100000 I (90) boot: End of partition table I (94) boot_comm: chip revision: 3, min. application chip revision: 0 I (101) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=2197ch (137596) map I (160) esp_image: segment 1: paddr=000319a4 vaddr=3ffb0000 size=03928h ( 14632) load I (166) esp_image: segment 2: paddr=000352d4 vaddr=40080000 size=0ad44h ( 44356) load I (184) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=a1f5ch (663388) map I (424) esp_image: segment 4: paddr=000e1f84 vaddr=4008ad44 size=0b658h ( 46680) load I (444) esp_image: segment 5: paddr=000ed5e4 vaddr=50000000 size=00010h ( 16) load I (455) boot: Loaded app from partition at offset 0x10000 I (455) boot: Disabling RNG early entropy source... I (466) cpu_start: Pro cpu up. I (467) cpu_start: Starting app cpu, entry point is 0x40081368 0x40081368: call_start_cpu1 at D:/esp/esp-idf/components/esp_system/port/cpu_start.c:156 I (0) cpu_start: App cpu up. I (481) cpu_start: Pro cpu start user code I (481) cpu_start: cpu freq: 160000000 I (481) cpu_start: Application information: I (485) cpu_start: Project name: record_raw_http I (491) cpu_start: App version: 1 I (495) cpu_start: Compile time: Mar 21 2022 14:41:15 I (502) cpu_start: ELF file SHA256: bba8125492dc4644... I (507) cpu_start: ESP-IDF: v4.4-dirty I (513) heap_init: Initializing. RAM available for dynamic allocation: I (520) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (526) heap_init: At 3FFB7890 len 00028770 (161 KiB): DRAM I (532) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (539) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (545) heap_init: At 4009639C len 00009C64 (39 KiB): IRAM I (552) spi_flash: detected chip: gd I (556) spi_flash: flash io: dio I (561) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (645) REC_RAW_HTTP: [ 1 ] Initialize Button Peripheral & Connect to wifi network W (3325) wifi: W (3425) PERIPH_WIFI: WiFi Event cb, Unhandle event_base:WIFI_EVENT, event_id:4 I (5145) REC_RAW_HTTP: [ 2 ] Start codec chip W (5175) I2C_BUS: i2c_bus_create:57: I2C bus has been already created, [port:0] I (5185) REC_RAW_HTTP: [3.0] Create audio pipeline for recording I (5185) REC_RAW_HTTP: [3.1] Create http stream to post data to server I (5185) REC_RAW_HTTP: [3.2] Create i2s stream to read audio data from codec chip I (5195) REC_RAW_HTTP: [3.3] Register all elements to audio pipeline I (5205) REC_RAW_HTTP: [3.4] Link it together [codec_chip]-->i2s_stream->http_stream-->[http_server] I (5215) REC_RAW_HTTP: [ 4 ] Press [Rec] button to record, Press [Mode] to exit W (30175) wifi: 麻烦大佬们帮忙解惑,感谢!(抱拳) |
180个成员聚集在这个小组
加入小组453 浏览 1 评论
1450 浏览 1 评论
618浏览 6评论
515浏览 5评论
494浏览 5评论
496浏览 4评论
486浏览 4评论
GMT+8, 2025-2-2 18:59 , Processed in 0.644157 second(s), Total 39, Slave 34 queries .
