下面是打印log信息 ,连接不成功直接给断开事件。 [16:13:05.299]收←◆WIFI 扫描完成 扫描到:10个ap信息 [0]: ssid:zzq123 rssi:-35 auth:3 [1]: ssid:305 rssi:-48 auth:4 [2]: ssid:305-dev rssi:-53 auth:4 [3]: ssid:TQLS-YFB rssi:-58 auth:4 [4]: ssid:TQLS-MY-LeiWY rssi:-63 auth:4 [5]: ssid:TQLSFYGS rssi:-64 auth:4 [6]: ssid:DIRECT-81-HP B310 rssi:-65 auth:3 [7]: ssid:LiQ_mytqls rssi:-72 auth:4 [8]: ssid:DIRECT-9E-EPSON-C887FF rssi:-77 auth:3 [9]: ssid:TP-LINK_C636 rssi:-87 auth:4 找到相似可以连接的wifi: zzq123 [0]: ssid:zzq123 rssi:-35 auth:3 (char *)wifi_config.sta.ssid == zzq123 (char *)wifi_config.sta.ssid == 12345678 开始连接新的WIFI释放内存 I (146237) wifi:flush txq I (146238) wifi:stop sw txq I (146241) wifi:lmac stop hw txq [16:13:07.330]收←◆I (148269) wifi:mode : sta (30:c6:f7:56:3a:b4) I (148270) wifi:enable tsf 重新启动完成 wifi heart0 wifi 启动事件 [16:13:07.356]收←◆I (148300) wifi<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1 [16:13:07.819]收←◆wifi heart1 [16:13:08.138]收←◆I (149094) wifi:state: init -> auth (b0) [16:13:08.202]收←◆I (149155) wifi:state: auth -> assoc (0) I (149169) wifi:state: assoc -> run (10) [16:13:08.314]收←◆wifi heart2 [16:13:08.810]收←◆wifi heart3 [16:13:09.306]收←◆wifi h [16:13:09.328]收←◆eart4 [16:13:09.817]收←◆wifi heart5 [16:13:10.313]收←◆wifi heart6 [16:13:10.809]收←◆wifi heart7 [16:13:11.240]收←◆I (152202) wifi:state: run -> init (fc0) I (152203) [16:13:11.266]收←◆wifi<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1 I (152204) wifi<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1 wifi 断开事件 下面是代码,请大佬看指教一下 Code: [Select all] [Expand/Collapse]
GeSHi © Codebox Plus Extension |
142个成员聚集在这个小组
加入小组530浏览 6评论
447浏览 5评论
429浏览 5评论
425浏览 4评论
402浏览 4评论
GMT+8, 2024-11-10 16:38 , Processed in 0.527424 second(s), Total 43, Slave 38 queries .
