[root@localhost hello_world]# idf.py menuconfig
Executing action: menuconfig Running cmake in directory /root/esp/hello_world/build Executing "cmake -G 'Unix Makefiles' -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32c3 -DCCACHE_ENABLE=0 /root/esp/hello_world"... -- Found Git: /usr/bin/git (found version "1.8.3.1") fatal: Not a git repository (or any of the parent directories): .git CMake Error at build/CMakeFiles/git-data/grabRef.cmake:48 (file): file failed to open for reading (No such file or directory): /root/esp/hello_world/build/CMakeFiles/git-data/head-ref Call Stack (most recent call first): /root/esp/esp-idf/tools/cmake/third_party/GetGitRevisionDescription.cmake:80 (include) /root/esp/esp-idf/tools/cmake/third_party/GetGitRevisionDescription.cmake:90 (get_git_head_revision) /root/esp/esp-idf/tools/cmake/project.cmake:59 (git_describe) /root/esp/esp-idf/tools/cmake/project.cmake:380 (__project_get_revision) CMakeLists.txt:6 (project) -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32c3 -- Project sdkconfig file /root/esp/hello_world/sdkconfig CMake Error at /root/esp/esp-idf/tools/cmake/component.cmake:300 (message): Include directory '/root/esp/esp-idf/components/mbedtls/mbedtls/include' is not a directory. Call Stack (most recent call first): /root/esp/esp-idf/tools/cmake/component.cmake:473 (__component_add_include_dirs) /root/esp/esp-idf/components/mbedtls/CMakeLists.txt:18 (idf_component_register) -- Configuring incomplete, errors occurred! See also "/root/esp/hello_world/build/CMakeFiles/CMakeOutput.log". cmake failed with exit code 1 [root@localhost hello_world]# |
171个成员聚集在这个小组
加入小组343 浏览 0 评论
1192 浏览 1 评论
587浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
443浏览 4评论
GMT+8, 2024-12-28 10:04 , Processed in 0.529006 second(s), Total 41, Slave 36 queries .
