如下日志,我买了几个ESP32S3模组的开发板,一个是ESP32-S3-DevKitC-1 v1.1,一个是ESP32-S3-Korvo-2 V3.0。我在烧写带语音识别的代码时,启用有一个4150KB的模组镜像。我发现在烧写的时候,32MB模组的flash大小都读取不到,那么在烧写的时候就烧写失败,日志如下。麻烦确认一下是什么问题,是否可以通过修改配置文件解决。
--------------------------ESP32-S3-Korvo-2 V3.0------的日志------- PS D:softwareEspressifframeworksesp-idf-v4.4.1> esptool.py -p COM22 flash_id esptool.py v3.3-dev Serial port COM22 Connecting.... Detecting chip type... ESP32-S3 Chip is ESP32-S3 Features: WiFi, BLE Crystal is 40MHz MAC: 7c:df:a1:e7:7a:a8 Uploading stub... Running stub... Stub running... Manufacturer: c8 Device: 4018 Detected flash size: 16MB Hard resetting via RTS pin... --------------------------------------------ESP32-S3-DevKitC-1 v1.1--------------32MB版本的开发板日志---------------- PS D:softwareEspressifframeworksesp-idf-v4.4.1> esptool.py -p COM5 flash_id esptool.py v3.3-dev Serial port COM5 Connecting.... Detecting chip type... ESP32-S3 Chip is ESP32-S3 Features: WiFi, BLE Crystal is 40MHz MAC: 7c:df:a1:e1:10:c4 Uploading stub... Running stub... Stub running... Manufacturer: c2 Device: 8039 Detected flash size: Unknown Hard resetting via RTS pin... -------------------------------------烧写失败的日志----------------------------------- esptool.py v3.3-dev Serial port COM5 Connecting.... Chip is ESP32-S3 Features: WiFi, BLE Crystal is 40MHz MAC: 7c:df:a1:e1:10:c4 Uploading stub... Running stub... Stub running... Changing baud rate to 460800 Changed. Configuring flash size... Warning: Could not auto-detect Flash size (FlashID=0x3980c2, SizeID=0x39), defaulting to 4MB A fatal error occurred: File model.bin (length 4251648) at offset 2752512 will not fit in 4194304 bytes of flash. Use --flash_size argument, or change flashing address. |
192个成员聚集在这个小组
加入小组470 浏览 1 评论
1648 浏览 2 评论
644浏览 6评论
536浏览 5评论
515浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-23 20:30 , Processed in 0.814574 second(s), Total 75, Slave 59 queries .
