目前使用两块esp32s3 模组 ,使用的是ESP IDF
父节点 一直报错: 非法子节点 (493102) mesh: 1316[recv]invalid child 68:b6:b3:3c:64:68 I (493102) mesh: 1316[recv]invalid child 68:b6:b3:3c:64:68 [0;32mI (493532) mesh_mqtt: MQTT_EVENT_PUBLISHED, msg_id=62348[0m [0;32mI (493812) mesh_main: Tried to publish layer:1 IP:192.168.137.154[0m [0;32mI (493812) mesh_mqtt: sent publish returned msg_id=1258[0m [0;32mI (493812) mesh_main: Sending routing table to [0] f4:12:fa [0;32mI (493812) mesh_main: Received Routing table [0] f4:12:fa 子节点 上电log如下: I (7036) wifi:mode : sta (68:b6:b3:3c:64:68) + softAP (68:b6:b3:3c:64:69) W (7056) wifi: I (7066) wifi:Total power save buffer number: 16 [0;32mI (7066) mesh_main: W (7096) wifi: I (7096) wifi:Total power save buffer number: 16 [22:29:38.022]收←◆I (7406) mesh: [SCAN][ch:6]AP:6, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:0,i:0][0e:9a:3c:87:53:52]router found<> I (7406) mesh: 7369[selection]try rssi_threshold:-78, backoff times:0, max:5<-78,-82,-85> I (7416) mesh: [DONE]connect to parent:ESPM_CD2660, channel:6, rssi:-5, f4:12:fa I (7426) mesh: set router bssid:0e:9a:3c:87:53:52 [22:29:38.284]收←◆I (7666) wifi [22:29:39.279]收←◆I (8656) wifi:state: init -> auth (b0) I (8676) wifi:state: auth -> assoc (0) E (8686) wifi:Association refused temporarily, comeback time 1536 mSec [22:29:40.837]收←◆I (10216) wifi:state: assoc -> assoc (0) I (10236) wifi:state: assoc -> run (10) I (10236) mesh: I (10236) mesh: I (10236) mesh: I (10246) wifi:connected with ESPM_CD2660, aid = 1, channel 6, 40U, bssid = f4:12:fa I (10256) wifi:security: WPA2-PSK, phy: bgn, rssi: -5 [0;32mI (10266) mesh_main: [22:29:40.930]收←◆I (10316) wifi:pm start, type: 0 I (10316) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000 I (10316) mesh: [scan]new scanning time:600ms, beacon interval:300ms I (10326) mesh: 2004 I (10326) wifi:BcnInt:102400, DTIM:1 [0;32mI (10336) mesh_main: [0;32mI (10346) mesh_netif: It was a wifi station removing stuff[0m [0;32mI (10356) mesh_main: [22:29:52.825]收←◆I (22206) mesh: 5156 [22:29:54.330]收←◆I (23716) mesh: 5947 I (23716) mesh: [SCAN][ch:6]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][0e:9a:3c:87:53:52] I (23716) mesh: 7369[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85> I (23726) mesh: 716[monitor]no change, parent:f4:12:fa I (23736) mesh: 2004 [22:30:06.507]收←◆I (35886) mesh: 5156 [22:30:08.010]收←◆I (37396) mesh: 5947 I (37396) mesh: [SCAN][ch:6]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][0e:9a:3c:87:53:52] I (37396) mesh: 7369[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85> I (37406) mesh: 716[monitor]no change, parent:f4:12:fa I (37416) mesh: 2004 [22:30:12.792]收←◆I (42176) mesh: 5156 [22:30:14.297]收←◆I (43676) mesh: 5947 I (43676) mesh: [SCAN][ch:6]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][0e:9a:3c:87:53:52] I (43686) mesh: 7369[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85> I (43696) mesh: 716[monitor]no change, parent:f4:12:fa I (43706) mesh: 2004 求大佬们帮忙看一下 |
171个成员聚集在这个小组
加入小组343 浏览 0 评论
1192 浏览 1 评论
587浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
443浏览 4评论
GMT+8, 2024-12-28 11:42 , Processed in 0.692923 second(s), Total 40, Slave 35 queries .
