ESP32模块使用WIFI连接路由器,在使用SOCKET进行UDP通信时,发现在某些路由器下发不出数据,在同一个地方,连接华为的路由器可以正常通信,连接带光猫的天翼路由器则发出的数据收不到,也不能接收客户端发过来的数据,造成产品的兼容性不好,不知道有没遇到类似的情况?测试代码如下:
recSocket = CreateUDPClient(NET_CFG_LISTEN_PORT); ESP_LOGI(TAG,"Create Config listen socket!,socket:%d",recSocket); if(recSocket<=0){ ESP_LOGE(TAG,"Create listen socket fail"); return; } rec_buffer = audio_malloc(NET_CFG_RECBUFF_SIZE*sizeof(char)); if(rec_buffer == NULL){ ESP_LOGE(TAG,"Memory exhaust!"); return; } struct sockaddr_in peerAddr; socklen_t peerLen = sizeof(peerAddr); while(1){ NetworkConfigSend(dest_ip_address,"Hello",5); memset(rec_buffer,0,NET_CFG_RECBUFF_SIZE); if(recSocket>0){ ESP_LOGE(TAG,"Read socket data!"); //bytes_read = read (recSocket, rec_buffer, NET_CFG_RECBUFF_SIZE); bytes_read = recvfrom(recSocket,rec_buffer,NET_CFG_RECBUFF_SIZE,0,(struct sockaddr *)&peerAddr,&peerLen); if(bytes_read>0){ ESP_LOGI(TAG,"Receive packet:%s,bytes:%d",rec_buffer,bytes_read); ESP_LOGI(TAG,"peer address = %s:%dn", inet_ntoa(peerAddr.sin_addr), ntohs(peerAddr.sin_port)); if(NetCommandProcess(rec_buffer)>0){ ESP_LOGI(TAG,"Command process OK"); } dest_ip_address = peerAddr.sin_addr.s_addr; } if(bytes_read < 0){ ESP_LOGE(TAG,"UDP Receive had error!Reset socket.."); recSocket = 0; } else{ ESP_LOGE(TAG,"Rec timeout"); } }else{ vTaskDelay(2000); recSocket = CreateUDPClient(NET_CFG_LISTEN_PORT); ESP_LOGI(TAG,"Create Config listen socket!,socket:%d",recSocket); if(recSocket<=0){ ESP_LOGE(TAG,"UDP Create faile!"); break; } } } |
196个成员聚集在这个小组
加入小组481 浏览 1 评论
1770 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
383浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
176浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
222浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
575浏览 2评论
265浏览 2评论
GMT+8, 2025-3-5 10:05 , Processed in 0.706204 second(s), Total 41, Slave 36 queries .
