搭建esp32-C3编译环境报错
按照入门说明esp-idf编译配置ok 但esp32-AT安装环境时报错 请帮忙看看 esp-idf 版本release/v4.3 esp-AT 版本v2.4.0.0 sudo ./build.py install ...... Traceback (most recent call last): File "esp-idf/tools/idf_tools.py", line 1852, in main(sys.argv[1:]) File "esp-idf/tools/idf_tools.py", line 1848, in main action_func(args) File "esp-idf/tools/idf_tools.py", line 1415, in action_install targets = clean_targets(args.targets) File "esp-idf/tools/idf_tools.py", line 1078, in clean_targets export_targets_to_idf_env_json(targets_from_tools_json) File "esp-idf/tools/idf_tools.py", line 1046, in export_targets_to_idf_env_json targets = list(set(targets + get_user_defined_targets())) File "esp-idf/tools/idf_tools.py", line 1092, in get_user_defined_targets if env == idf_env_json['idfSelectedId']: KeyError: 'idfSelectedId' A fatal error occurred: set up ESP-IDF toolchains failed |
171个成员聚集在这个小组
加入小组350 浏览 0 评论
1196 浏览 1 评论
588浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
443浏览 4评论
GMT+8, 2024-12-29 08:47 , Processed in 0.609152 second(s), Total 41, Slave 36 queries .
