这是为了在 LCD 上显示进入 ADC IN0 的电压。
我用的是TouchGFX + CubeIDE编译器,但是出现了错误。 在 YouTube 上,它可以正常编译。请告诉我错误发生的原因。 的 使-j12全部 arm-none-eabi-g++ "../TouchGFX/gui/src/screen1_screen/Screen1View.cpp" -mcpu=cortex-m7 -std=gnu++14 -g3 -DUSE_HAL_DRIVER -DSTM32F746xx -DDEBUG -c -I.. /TouchGFX/gui/include -I../TouchGFX/generated/fonts/include -I"C:/ST/STM32CubeIDE_1.3.0/SWTEST/Drivers/Components" -I"C:/ST/STM32CubeIDE_1.3.0/SWTEST/驱动程序/组件/n25q128a" -I../TouchGFX/generated/texts/include -I../Drivers/STM32F7xx_HAL_Driver/Inc -I../TouchGFX/generated/images/include -I"C:/TouchGFXProjects/SWITCHTEST/ Drivers/Components/Common" -I"C:/ST/STM32CubeIDE_1.3.0/SWTEST/Drivers/Components/ft5336" -I"C:/TouchGFXProjects/SWITCHTEST/Drivers/Components/n25q128a" -I../Core/Inc -I../TouchGFX/generated/gui_generated/include -I"C:/ST/STM32CubeIDE_1.3.0/SWTEST/Drivers/Components/Common" -I"C:/TouchGFXProjects/SWITCHTEST/Drivers/Components/ft5336" -I../Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -I../Drivers/STM32F7xx_HAL_Driver/Inc/Legacy -I../Middlewares/Third_Party/FreeRTOS/Source/包括 -I../Drivers/CMSIS/Device/ST/STM32F7xx/Include -I../Middlewares/ST/touchgfx/framework/include -I"C:/ST/STM32CubeIDE_1.3.0/SWTEST/Drivers/BSP" - I../TouchGFX/target/generated -I../Drivers/CMSIS/Include -I../Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM7/r0p1 -I../TouchGFX/App -I. ./TouchGFX/target -O0 -ffunction-sections -fdata-sections -fno-exceptions -fno-rtti -fno-threadsafe-statics -fno-use-cxa-atexit -Wall -fstack-usage -MMD -MP -MF” TouchGFX/gui/src/screen1_screen/Screen1View.d" -MT"TouchGFX/gui/src/screen1_screen/Screen1View.o" --specs=nano。规格 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -o "TouchGFX/gui/src/screen1_screen/Screen1View.o" ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp: 在成员函数'virtual void Screen1View::analogUpdate(uint32_t)'中: ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp:19:10: 错误:'textAreaADBuffer' 未在此范围内声明 memset(&textAreaADBuffer, 0, TEXTAREAAD_SIZE); ^~~~~~~~~~~~~~~~ ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp:19:10: 注意:建议的替代方案:'textArea1' memset(&textAreaADBuffer, 0, TEXTAREAAD_SIZE); ^~~~~~~~~~~~~~~~ 文字区域1 ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp:19:31: 错误:'TEXTAREAD_SIZE' 未在此范围内声明 memset(&textAreaADBuffer, 0, TEXTAREAAD_SIZE); ^~~~~~~~~~~~~~~ ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp:19:31: 注意:建议的替代方案:'TEXTAREA_HPP' memset(&textAreaADBuffer, 0, TEXTAREAAD_SIZE); ^~~~~~~~~~~~~~~ 文本区域_HPP ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp:21:2: 错误:'textAreaAD' 未在此范围内声明 textAreaAD.invalidate(); ^~~~~~~~~~ ../TouchGFX/gui/src/screen1_screen/Screen1View.cpp:21:2: 注意:建议的替代方案:'textArea1' textAreaAD.invalidate(); ^~~~~~~~~~ 文字区域1 make: *** [TouchGFX/gui/src/screen1_screen/ subdir.mk:23: TouchGFX/gui/src/screen1_screen/Screen1View.o] 错误 1 “make -j12 all”以退出代码 2 终止。构建可能不完整。 我看过你的 YouTube 并试过了。但是,出现了一些错误。 有些变量没有声明,如何解决? void Screen1View::analogUpdate(uint32_t 值) { memset(&textAreaADBuffer, 0, TEXTAREAAD_SIZE); Unicode::snprintfFloat(textAreaADBuffer, sizeof(textAreaADBuffer), "%.3f", value * 0.000805664 ); // 3.3/4096 = 0.000805664 textAreaAD.invalidate(); } 我试图在 LCD 屏幕上显示模拟输入电压,但屏幕查看器功能出现错误。这个问题让我恶心了一个星期。我想上传一个合适的 YouTube。上传YouTube的人要详细上传怎么没有出现错误。 有人可以帮帮我吗。 看起来很疯狂。 |
在ADC转换完成回调中,设置一个标志。使用此标志轮询转换结束。然后重新初始化 ADC 转换。
2985 浏览 1 评论
3313 浏览 1 评论
1894 浏览 1 评论
3748 浏览 6 评论
6164 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
57浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
60浏览 5评论
92浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
60浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
56浏览 5评论
GMT+8, 2025-4-6 16:27 , Processed in 0.521765 second(s), Total 42, Slave 37 queries .
