扫一扫,分享给好友
最近烧写mmc,发现uboot内saveenv命令丢失,导致环境变量无法设置,请教了
...... md - memory display mii - MII utility commands mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - display MMC info mtest - ** RAM read/write test mw - memory write (fill) nfs - boot image via network using NFS protocol nm - memory modify (constant address) ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables protect - enable or disable FLASH write protection rarpboot- boot image via network using RARP/TFTP protocol reset - Perform RESET of the CPU run - run commands in an environment variable setenv - set environment variables sf - SPI flash sub-system sleep - delay execution for some time source - run script from memory sspi - SPI utility commands tftpboot- boot image via network using TFTP protocol version - print monitor version ...... |
我们的uboot?您怎么弄的会缺失这个,重新烧写吧
935 浏览 0 评论
1237 浏览 1 评论
2600 浏览 5 评论
2937 浏览 9 评论
2803 浏览 6 评论
1343浏览 3评论
247浏览 2评论
521浏览 2评论
429浏览 2评论
505浏览 1评论
GMT+8, 2025-2-24 05:21 , Processed in 1.093371 second(s), Total 79, Slave 60 queries .
