你用什么芯片?用free命令看看还剩下多少内存。
stm32是在board.h中设置的 #define STM32_SRAM_SIZE (128) #define STM32_SRAM_END (0x20000000 + STM32_SRAM_SIZE * 1024) |
下线程栈,启动后会出现奇迹,但是用一下免费就又挂了
msh />free total memory: 523885944 used memory : 8760 maximum allocated memory: 15288data abort:Execption: r00:0x00000000 r01:0x00000000 r02:0x8005a824 r03:0x0000000c r04:0x8003cce0 r05:0xdeadbeef r06:0xdeadbeef r07:0xdeadbeef r08:0x80064bc0 r09:0xdeadbeef r10:0xdeadbeef fp :0x800560ac ip :0x80063a0e sp :0x80064c08 lr :0x8003b814 pc :0x80018c3c cpsr:0x60000192 thread cpu pri status sp stack size max used left tick error -------- --- --- ------- ---------- ---------- ------ ---------- --- tshell 0 20 running 0x000000d0 0x00001000 92% 0x0000000a 000 sys_work N/A 23 suspend 0x00000088 0x00000800 89% 0x0000000a 000 tidle3 N/A 31 ready 0x00000048 0x00000400 90% 0x00000020 000 tidle2 N/A 31 ready 0x00000048 0x00000400 71% 0x00000020 000 tidle1 N/A 31 ready 0x00000048 0x00000400 71% 0x00000020 000 tidle0 N/A 31 ready 0x00000064 0x00000400 71% 0x00000014 000 timer 0 0 init 0x8005a818 0x00000400 96% 0x00000009 000 shutdown... (0) assertion failed at function:rt_hw_cpu_shutdown, line number:85 |
先查看下你的芯片ram有多大,然后分配空间,rtthread栈设置是在rt_system_heap_init函数中设置的
AI模型部署边缘设备的奇妙之旅:边缘端设备的局域网视频流传输方案
1618 浏览 0 评论
1486 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
6723 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1867 浏览 0 评论
3638 浏览 0 评论
78370 浏览 21 评论
GMT+8, 2025-1-25 09:24 , Processed in 0.378699 second(s), Total 40, Slave 35 queries .
