[文章]【开鸿智谷NiobeU4开发板免费试用体验】终章 数据通路
一、简单说明
利用之前的功能,将数据通路打通,即开发板连接上wifi后,尝试连接服务器,连接成功服务器后可以进行数据通信。将读到的nfc卡信息和按键信息发送给服务器。
二、遇到的问题
在向服务器发送数据的时候,例程里面是用的write函数,
write(sock, recv_data, recv_data_len);
连接上服务器后,能收到服务器发送过来的数据,但是使用write接口始终发送不了给服务器。一度怀疑是服务器的问题。找了很久才知道要用send函数。这点很坑!!!!
send(sock, recv_data, strlen(recv_data), 0);
三、大体测试代码
测试代码,能实现大体功能,健壮性就暂时不考虑了、、、
static void user_app(void)
    unsigned char nfcFlag = 0;
    unsigned char nfc_Buf[4] = {0};
    unsigned char key_value = 0;
    int sock = -1;
    struct sockaddr_in client_addr;
    char recv_data[512] = {0};
    int recv_data_len;
    led_init();
    WifiConnect(WIFI_NAME, WIFI_PWD);
    printf("start wifi_test test\r\n");
    adc_init();
    NfcExtExample();
    while (1)
        sock = socket(AF_INET, SOCK_STREAM, 0);
        if (sock < 0) {
            printf("Socket error\n");
            osDelay(OD_DELAY_100);
            continue;
        memset_s(&(client_addr), sizeof(client_addr), 0, sizeof(client_addr));
        client_addr.sin_family = AF_INET;
        client_addr.sin_port = htons(SERVER_PORT);
        client_addr.sin_addr.s_addr = inet_addr(SERVER_IP);
        printf("try connect to server "SERVER_IP" :%d \n", SERVER_PORT);
        if (connect(sock, (struct sockaddr *)&client_addr, sizeof(struct sockaddr)) == -1) {
            closesocket(sock);
            osDelay(OD_DELAY_1000);
            continue;
        printf("Connect to tcp server successful!\n");
        while (1) {
            key_value = key_process();
            if (key_value == 4)
            	memset(recv_data, 0, 100);
                sprintf(recv_data, "key up press\r\n");
            else if (key_value == 5)
            	sprintf(recv_data, "key down press\r\n");
            if(key_value)
                led_blue_on();
            nfcFlag = get_NFC_ID(nfc_Buf);
            if (nfcFlag)
                led_blue_on();
                sprintf(recv_data, "NFC ID: %02X %02X %02X %02X\r\n", nfc_Buf[0], nfc_Buf[1], nfc_Buf[2], nfc_Buf[3]);
