一,首先感谢上海航芯提供这次测试机会。
2022-10-17收到的开发板。
二,这款芯片吸引人的地方,高主频,M33内核(以前没用过),大的RAM。 (ACM32F403芯片 的内核 基于 ARMv8-M架构 ,支持 Cortex-M33和 Cortex-M4F指令集 , 系统最高频率达 180 MHz )
三,手里正好有一块TFT LCD,1.8",160*128.SPI接口的。
四,硬件连接如下:
#define LCD_RST_Pin GPIO_PIN_10
#define LCD_RST_GPIO_Port GPIOB
#define LCD_DC_Pin GPIO_PIN_11
#define LCD_DC_GPIO_Port GPIOB
#define LCD_CS_Pin GPIO_PIN_12
#define LCD_CS_GPIO_Port GPIOB
#define LCD_BL_Pin GPIO_PIN_14
#define LCD_BL_GPIO_Port GPIOB
#define LCD_SCL_Pin GPIO_PIN_13
#define LCD_SCL_GPIO_Port GPIOB
#define LCD_MOSI_Pin GPIO_PIN_15
#define LCD_MOSI_GPIO_Port GPIOB
#define TFT_BL_H() HAL_GPIO_WritePin(LCD_BL_GPIO_Port, LCD_BL_Pin, GPIO_PIN_SET) //SET
#define TFT_BL_L() HAL_GPIO_WritePin(LCD_BL_GPIO_Port, LCD_BL_Pin, GPIO_PIN_CLEAR) //RESET
#define TFT_CS_H() HAL_GPIO_WritePin(LCD_CS_GPIO_Port, LCD_CS_Pin, GPIO_PIN_SET)
#define TFT_CS_L() HAL_GPIO_WritePin(LCD_CS_GPIO_Port, LCD_CS_Pin, GPIO_PIN_CLEAR)
#define TFT_DC_D() HAL_GPIO_WritePin(LCD_DC_GPIO_Port, LCD_DC_Pin, GPIO_PIN_SET)
#define TFT_DC_C() HAL_GPIO_WritePin(LCD_DC_GPIO_Port, LCD_DC_Pin, GPIO_PIN_CLEAR)
#define TFT_RES_H() HAL_GPIO_WritePin(LCD_RST_GPIO_Port, LCD_RST_Pin, GPIO_PIN_SET)
#define TFT_RES_L() HAL_GPIO_WritePin(LCD_RST_GPIO_Port, LCD_RST_Pin, GPIO_PIN_CLEAR)
五,初始化程序如下:
一,首先感谢上海航芯提供这次测试机会。
2022-10-17收到的开发板。
二,这款芯片吸引人的地方,高主频,M33内核(以前没用过),大的RAM。(ACM32F403芯片 的内核 基于 ARMv8-M架构 ,支持 Cortex-M33和 Cortex-M4F指令集 , 系统最高频率达 180 MHz)
四,硬件连接如下:
五,初始化程序如下:
void ST7735_Spi2_Init(void)
SPI_Handle.Instance = SPI2;
SPI_Handle.Init.SPI_Mode = SPI_MODE_MASTER;
SPI_Handle.Init.SPI_Work_Mode = SPI_WORK_MODE_0;
SPI_Handle.Init.X_Mode = SPI_1X_MODE;
SPI_Handle.Init.First_Bit = SPI_FIRSTBIT_MSB;
SPI_Handle.Init.BaudRate_Prescaler = SPI_BAUDRATE_PRESCALER_254;
HAL_SPI_Init(&SPI_Handle);
HAL_SPI_Wire_Config(&SPI_Handle, SPI_1X_MODE);
OLED_CS_Set();
System_Delay(1000);
void ST7735_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct ={0};
System_Module_Enable(EN_GPIOAB);
System_Module_Enable(EN_SPI2);
GPIO_InitStruct.Pin = GPIO_PIN_13 | GPIO_PIN_15;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Alternate = GPIO_FUNCTION_4;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_11|GPIO_PIN_12 |GPIO_PIN_14 ;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Alternate = GPIO_FUNCTION_0;
ST7735_Spi2_Init();
SPI2_ReadWriteByte(0xff);
void ST7735_write(uint8_t data) {
HAL_SPI_Transmit(&SPI_Handle, &data, sizeof(data), 1000);
void ST7735_cmd(unsigned int cmd) {
OLED_CS_Clr();
OLED_DC_Clr();
ST7735_write(cmd);
OLED_CS_Set();
void ST7735_data(unsigned int data) {
OLED_CS_Clr();
OLED_DC_Set();
ST7735_write(data);
OLED_CS_Set();
void writeCmdData ( unsigned char Byte, unsigned char opt ) {
if ( opt == 1 ) {
OLED_DC_Clr();
} else if ( opt == 0 ) {
OLED_DC_Set();
OLED_CS_Clr();
ST7735_write(Byte);
OLED_CS_Set(); //取消片选
uint16_t RGB565(uint8_t R,uint8_t G,uint8_t B) {
return ((R >> 3) << 11) | ((G >> 2) << 5) | (B >> 3);
FontDef Font_7x10 = {7,10,Font7x10};
FontDef Font_11x18 = {11,18,Font11x18};
FontDef Font_16x26 = {16,26,Font16x26};
#define ST7735_COLOR565(r, g, b) (((r & 0xF8) << 8) | ((g & 0xFC) << 3) | ((b & 0xF8) >> 3))
#define SWAP_INT16_T(a, b)
int16_t t = a;
a = b;
b = t;
#define DELAY 0x80
#if defined(ST7735_1_8_DEFAULT_ORIENTATION) || defined(ST7735S_1_8_DEFAULT_ORIENTATION)
static uint8_t _data_rotation[4] = {ST7735_MADCTL_MX, ST7735_MADCTL_MY, ST7735_MADCTL_MV, ST7735_MADCTL_RGB};
#endif
#if defined(ST7735_1_44_DEFAULT_ORIENTATION) || defined(ST7735_MINI_DEFAULT_ORIENTATION)
static uint8_t _data_rotation[4] = {ST7735_MADCTL_MX, ST7735_MADCTL_MY, ST7735_MADCTL_MV, ST7735_MADCTL_BGR};
#endif
static uint8_t _value_rotation = 0;
static int16_t _height = ST7735_HEIGHT, _width = ST7735_WIDTH;
static uint8_t _xstart = ST7735_XSTART, _ystart = ST7735_YSTART;
// based on Adafruit ST7735 library for Arduino
static const uint8_t
init_cmds1[] = { // Init for 7735R, part 1 (red or green tab)
15, // 15 commands in list:
ST7735_SWRESET, DELAY, // 1: Software reset, 0 args, w/delay
150, // 150 ms delay
ST7735_SLPOUT, DELAY, // 2: Out of sleep mode, 0 args, w/delay
255, // 500 ms delay
ST7735_FRMCTR1, 3, // 3: Frame rate ctrl - normal mode, 3 args:
0x01, 0x2C, 0x2D, // Rate = fosc/(1x2+40) * (LINE+2C+2D)
ST7735_FRMCTR2, 3, // 4: Frame rate control - idle mode, 3 args:
ST7735_FRMCTR3, 6, // 5: Frame rate ctrl - partial mode, 6 args:
0x01, 0x2C, 0x2D, // Dot inversion mode
0x01, 0x2C, 0x2D, // Line inversion mode
ST7735_INVCTR, 1, // 6: Display inversion ctrl, 1 arg, no delay:
0x07, // No inversion
ST7735_PWCTR1, 3, // 7: Power control, 3 args, no delay:
0xA2,
0x02, // -4.6V
0x84, // AUTO mode
ST7735_PWCTR2, 1, // 8: Power control, 1 arg, no delay:
0xC5, // VGH25 = 2.4C VGSEL = -10 VGH = 3 * AVDD
ST7735_PWCTR3, 2, // 9: Power control, 2 args, no delay:
0x0A, // Opamp current small
0x00, // Boost frequency
ST7735_PWCTR4, 2, // 10: Power control, 2 args, no delay:
0x8A, // BCLK/2, Opamp current small & Medium low
0x2A,
ST7735_PWCTR5, 2, // 11: Power control, 2 args, no delay:
0x8A, 0xEE,
ST7735_VMCTR1, 1, // 12: Power control, 1 arg, no delay:
0x0E,
ST7735_INVOFF, 0, // 13: Don't invert display, no args, no delay
ST7735_MADCTL, 1, // 14: Memory access control (directions), 1 arg:
ST7735_DATA_ROTATION, // row addr/col addr, bottom to top refresh
ST7735_COLMOD, 1, // 15: set color mode, 1 arg, no delay:
0x05}, // 16-bit color
#if (defined(ST7735_IS_128X128) || defined(ST7735_IS_160X128))
init_cmds2[] = { // Init for 7735R, part 2 (1.44" display)
2, // 2 commands in list:
ST7735_CASET, 4, // 1: Column addr set, 4 args, no delay:
0x00, 0x00, // XSTART = 0
0x00, 0x7F, // XEND = 127
ST7735_RASET, 4, // 2: Row addr set, 4 args, no delay:
0x00, 0x7F}, // XEND = 127
#endif // ST7735_IS_128X128
#ifdef ST7735_IS_160X80
init_cmds2[] = { // Init for 7735S, part 2 (160x80 display)
3, // 3 commands in list:
0x00, 0x4F, // XEND = 79
0x00, 0x9F, // XEND = 159
ST7735_INVON, 0}, // 3: Invert colors
#endif
init_cmds3[] = { // Init for 7735R, part 3 (red or green tab)
4, // 4 commands in list:
ST7735_GMCTRP1, 16, // 1: Magical unicorn dust, 16 args, no delay:
0x02, 0x1c, 0x07, 0x12, 0x37, 0x32, 0x29, 0x2d, 0x29, 0x25, 0x2B, 0x39, 0x00, 0x01, 0x03, 0x10, ST7735_GMCTRN1, 16, // 2: Sparkles and rainbows, 16 args, no delay:
0x03, 0x1d, 0x07, 0x06, 0x2E, 0x2C, 0x29, 0x2D, 0x2E, 0x2E, 0x37, 0x3F, 0x00, 0x00, 0x02, 0x10, ST7735_NORON, DELAY, // 3: Normal display on, no args, w/delay
10, // 10 ms delay
ST7735_DISPON, DELAY, // 4: Main screen turn on, no args w/delay
100}; // 100 ms delay
static void ST7735_WriteCommand(uint8_t cmd);
static void ST7735_WriteData(uint8_t *buff, size_t buff_size);
static void ST7735_ExecuteCommandList(const uint8_t *addr);
static void ST7735_SetAddressWindow(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1);
static void ST7735_WriteChar(uint16_t x, uint16_t y, char ch, FontDef font, uint16_t color, uint16_t bgcolor);
static void ST7735_Reset()
TFT_RES_L();
HAL_Delay(20);
TFT_RES_H();
TFT_DC_C();
HAL_SPI_Transmit(&SPI_Handle, &cmd, sizeof(cmd), 1000);
//ST7735_cmd(cmd);
//size_t i=0;
//for(i=0;i<buff_size;i++)
// ST7735_data(buff[i]);
TFT_DC_D();
HAL_SPI_Transmit(&SPI_Handle, buff, buff_size, 1000);
uint8_t numCommands, numArgs;
uint16_t ms;
numCommands = *addr++;
while (numCommands--)
uint8_t cmd = *addr++;
ST7735_WriteCommand(cmd);
numArgs = *addr++;
// If high bit set, delay follows args
ms = numArgs & DELAY;
numArgs &= ~DELAY;
if (numArgs)
ST7735_WriteData((uint8_t *)addr, numArgs);
addr += numArgs;
if (ms)
ms = *addr++;
if (ms == 255)
ms = 500;
HAL_Delay(ms);
// column address set
uint8_t data[] = {0x00, x0 + _xstart, 0x00, x1 + _xstart};
ST7735_WriteCommand(ST7735_CASET);
ST7735_WriteData(data, sizeof(data));
// row address set
ST7735_WriteCommand(ST7735_RASET);
data[1] = y0 + _ystart;
data[3] = y1 + _ystart;
// write to RAM
ST7735_WriteCommand(ST7735_RAMWR);
uint32_t i, b, j;
ST7735_SetAddressWindow(x, y, x + font.width - 1, y + font.height - 1);
for (i = 0; i < font.height; i++)
b = font.data[(ch - 32) * font.height + i];
for (j = 0; j < font.width; j++)
if ((b << j) & 0x8000)
uint8_t data[] = {color >> 8, color & 0xFF};
else
uint8_t data[] = {bgcolor >> 8, bgcolor & 0xFF};
void ST7735_Init(void)
TFT_CS_L();
ST7735_Reset();
ST7735_ExecuteCommandList(init_cmds1);
ST7735_ExecuteCommandList(init_cmds2);
ST7735_ExecuteCommandList(init_cmds3);
TFT_CS_H();
void ST7735_DrawPixel(uint16_t x, uint16_t y, uint16_t color)
if ((x >= _width) || (y >= _height))
return;
TFT_CS_L();
ST7735_SetAddressWindow(x, y, x + 1, y + 1);
TFT_CS_H();
void ST7735_DrawString(uint16_t x, uint16_t y, const char *str, FontDef font, uint16_t color, uint16_t bgcolor)
TFT_CS_L();
while (*str)
if (x + font.width >= _width)
x = 0;
y += font.height;
if (y + font.height >= _height)
break;
if (*str == ' ')
str++;
continue;
ST7735_WriteChar(x, y, *str, font, color, bgcolor);
x += font.width;
str++;
TFT_CS_H();
void ST7735_FillRectangle(uint16_t x, uint16_t y, uint16_t w, uint16_t h, uint16_t color)
// clipping
return;
if ((x + w - 1) >= _width)
w = _width - x;
if ((y + h - 1) >= _height)
h = _height - y;
TFT_CS_L();
ST7735_SetAddressWindow(x, y, x + w - 1, y + h - 1);
uint8_t data[2] = {color >> 8, color & 0xFF};
TFT_DC_D();
#ifdef USE_SPI_DMA
uint8_t tbuf[w * 2];
for (y = h; y > 0; y--)
for (int x = w * 2; x >= 0; x -= 2)
tbuf[x] = data[0];
tbuf[x + 1] = data[1];
// HAL_SPI_Transmit_DMA(&ST7735_SPI_PORT, tbuf, sizeof(tbuf));
// while (hspi2.State == HAL_SPI_STATE_BUSY_TX)
#else
for (x = w; x > 0; x--)
//HAL_SPI_Transmit(&ST7735_SPI_PORT, data, sizeof(data), HAL_MAX_DELAY);
ST7735_data(data[0]>>8);
ST7735_data(data[1]);
#endif
TFT_CS_H();
void ST7735_FillScreen(uint16_t color)
ST7735_FillRectangle(0, 0, _width, _height, color);
void ST7735_DrawImage(uint16_t x, uint16_t y, uint16_t w, uint16_t h, const uint16_t *data)
return;
return;
return;
TFT_CS_L();
ST7735_WriteData((uint8_t *)data, sizeof(uint16_t) * w * h);
TFT_CS_H();
void ST7735_InvertColors(bool invert)
TFT_CS_L();
ST7735_WriteCommand(invert ? ST7735_INVON : ST7735_INVOFF);
TFT_CS_H();
void ST7735_Backlight_On(void)
TFT_BL_H();
void ST7735_Backlight_Off(void)
TFT_BL_L();
** Function name: drawCircle
** Description: Draw a circle outline
void ST7735_DrawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color)
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t ddF_y = -r - r;
int16_t x = 0;
ST7735_DrawPixel(x0 + r, y0, color);
ST7735_DrawPixel(x0 - r, y0, color);
ST7735_DrawPixel(x0, y0 - r, color);
ST7735_DrawPixel(x0, y0 + r, color);
while (x < r)
if (f >= 0)
r--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
ST7735_DrawPixel(x0 + x, y0 + r, color);
ST7735_DrawPixel(x0 - x, y0 + r, color);
ST7735_DrawPixel(x0 - x, y0 - r, color);
ST7735_DrawPixel(x0 + x, y0 - r, color);
ST7735_DrawPixel(x0 + r, y0 + x, color);
ST7735_DrawPixel(x0 - r, y0 + x, color);
ST7735_DrawPixel(x0 - r, y0 - x, color);
ST7735_DrawPixel(x0 + r, y0 - x, color);
** Function name: drawCircleHelper
** Description: Support function for circle drawing
void ST7735_DrawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, uint16_t color)
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t ddF_y = -2 * r;
int16_t x = 0;
while (x < r)
if (f >= 0)
r--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
if (cornername & 0x8)
if (cornername & 0x4)
if (cornername & 0x2)
if (cornername & 0x1)
** Function name: fillCircle
** Description: draw a filled circle
void ST7735_FillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color)
ST7735_DrawFastVLine(x0, y0 - r, r + r + 1, color);
ST7735_FillCircleHelper(x0, y0, r, 3, 0, color);
** Function name: fillCircleHelper
** Description: Support function for filled circle drawing
// Used to do circles and roundrects
void ST7735_FillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, int16_t delta, uint16_t color)
int16_t f = 1 - r;
int16_t ddF_x = 1;
int16_t x = 0;
delta++;
while (x < r)
if (f >= 0)
r--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
ST7735_DrawFastVLine(x0 + x, y0 - r, r + r + delta, color);
ST7735_DrawFastVLine(x0 + r, y0 - x, x + x + delta, color);
ST7735_DrawFastVLine(x0 - x, y0 - r, r + r + delta, color);
ST7735_DrawFastVLine(x0 - r, y0 - x, x + x + delta, color);
** Function name: drawEllipse
** Description: Draw a ellipse outline
void ST7735_DrawEllipse(int16_t x0, int16_t y0, int16_t rx, int16_t ry, uint16_t color)
if (rx < 2)
return;
if (ry < 2)
return;
int16_t x, y;
int32_t rx2 = rx * rx;
int32_t ry2 = ry * ry;
int32_t fx2 = 4 * rx2;
int32_t fy2 = 4 * ry2;
int32_t s;
for (x = 0, y = ry, s = 2 * ry2 + rx2 * (1 - 2 * ry); ry2 * x <= rx2 * y; x++)
ST7735_DrawPixel(x0 + x, y0 + y, color);
ST7735_DrawPixel(x0 - x, y0 + y, color);
ST7735_DrawPixel(x0 - x, y0 - y, color);
ST7735_DrawPixel(x0 + x, y0 - y, color);
if (s >= 0)
s += fx2 * (1 - y);
y--;
s += ry2 * ((4 * x) + 6);
for (x = rx, y = 0, s = 2 * rx2 + ry2 * (1 - 2 * rx); rx2 * y <= ry2 * x; y++)
if (s >= 0)
s += fy2 * (1 - x);
x--;
s += rx2 * ((4 * y) + 6);
** Function name: fillEllipse
** Description: draw a filled ellipse
void ST7735_FillEllipse(int16_t x0, int16_t y0, int16_t rx, int16_t ry, uint16_t color)
if (rx < 2)
return;
if (ry < 2)
return;
int16_t x, y;
int32_t s;
ST7735_DrawFastHLine(x0 - x, y0 - y, x + x + 1, color);
ST7735_DrawFastHLine(x0 - x, y0 + y, x + x + 1, color);
if (s >= 0)
s += fx2 * (1 - y);
y--;
if (s >= 0)
s += fy2 * (1 - x);
x--;
** Function name: drawRect
** Description: Draw a rectangle outline
// Draw a rectangle
void ST7735_DrawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)
ST7735_DrawFastHLine(x, y, w, color);
ST7735_DrawFastHLine(x, y + h - 1, w, color);
ST7735_DrawFastVLine(x, y, h, color);
ST7735_DrawFastVLine(x + w - 1, y, h, color);
** Function name: drawRoundRect
** Description: Draw a rounded corner rectangle outline
// Draw a rounded rectangle
void ST7735_DrawRoundRect(int16_t x, int16_t y, int16_t w, int16_t h, int16_t r, uint16_t color)
// smarter version
ST7735_DrawFastHLine(x + r, y, w - r - r, color); // Top
ST7735_DrawFastHLine(x + r, y + h - 1, w - r - r, color); // Bottom
ST7735_DrawFastVLine(x, y + r, h - r - r, color); // Left
ST7735_DrawFastVLine(x + w - 1, y + r, h - r - r, color); // Right
// draw four corners
ST7735_DrawCircleHelper(x + r, y + r, r, 1, color);
ST7735_DrawCircleHelper(x + r, y + h - r - 1, r, 8, color);
ST7735_DrawCircleHelper(x + w - r - 1, y + r, r, 2, color);
ST7735_DrawCircleHelper(x + w - r - 1, y + h - r - 1, r, 4, color);
** Function name: fillRoundRect
** Description: Draw a rounded corner filled rectangle
// Fill a rounded rectangle
void ST7735_FillRoundRect(int16_t x, int16_t y, int16_t w, int16_t h, int16_t r, uint16_t color)
// smarter version
ST7735_FillRectangle(x + r, y, w - r - r, h, color);
ST7735_FillCircleHelper(x + w - r - 1, y + r, r, 1, h - r - r - 1, color);
ST7735_FillCircleHelper(x + r, y + r, r, 2, h - r - r - 1, color);
** Function name: drawTriangle
** Description: Draw a triangle outline using 3 arbitrary points
// Draw a triangle
void ST7735_DrawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color)
ST7735_DrawLine(x0, y0, x1, y1, color);
ST7735_DrawLine(x1, y1, x2, y2, color);
ST7735_DrawLine(x2, y2, x0, y0, color);
** Function name: fillTriangle
** Description: Draw a filled triangle using 3 arbitrary points
// Fill a triangle - original Adafruit function works well and code footprint is small
void ST7735_FillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color)
int16_t a, b, y, last;
if (y0 > y1)
SWAP_INT16_T(y0, y1);
SWAP_INT16_T(x0, x1);
if (y1 > y2)
SWAP_INT16_T(y2, y1);
SWAP_INT16_T(x2, x1);
if (y0 > y1)
if (y0 == y2)
a = b = x0;
if (x1 < a)
a = x1;
else if (x1 > b)
b = x1;
if (x2 < a)
a = x2;
else if (x2 > b)
b = x2;
ST7735_DrawFastHLine(a, y0, b - a + 1, color);
return;
int16_t
dx01 = x1 - x0,
dy01 = y1 - y0,
dx02 = x2 - x0,
dy02 = y2 - y0,
dx12 = x2 - x1,
dy12 = y2 - y1,
sa = 0,
sb = 0;
if (y1 == y2)
last = y1;
else
last = y1 - 1;
for (y = y0; y <= last; y++)
a = x0 + sa / dy01;
b = x0 + sb / dy02;
sa += dx01;
sb += dx02;
if (a > b)
SWAP_INT16_T(a, b);
ST7735_DrawFastHLine(a, y, b - a + 1, color);
sa = dx12 * (y - y1);
sb = dx02 * (y - y0);
for (; y <= y2; y++)
a = x1 + sa / dy12;
b = x0 + sb / dy02;
sa += dx12;
sb += dx02;
if (a > b)
SWAP_INT16_T(a, b);
** Function name: drawLine
** Description: draw a line between 2 arbitrary points
// Slower but more compact line drawing function
void ST7735_DrawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color)
int16_t steep = abs(y1 - y0) > abs(x1 - x0);
if (steep)
SWAP_INT16_T(x0, y0);
SWAP_INT16_T(x1, y1);
if (x0 > x1)
int16_t dx, dy;
dx = x1 - x0;
dy = abs(y1 - y0);
int16_t err = dx / 2;
int16_t ystep;
if (y0 < y1)
ystep = 1;
else
ystep = -1;
for (; x0 <= x1; x0++)
if (steep)
ST7735_DrawPixel(y0, x0, color);
else
ST7735_DrawPixel(x0, y0, color);
err -= dy;
if (err < 0)
y0 += ystep;
err += dx;
** Function name: drawFastVLine
** Description: draw a vertical line
void ST7735_DrawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color)
// Rudimentary clipping
return;
h = _height - y;
#ifdef USE_SPI_DMA
ST7735_FillRectangle(x, y, 1, h, color);
#else
ST7735_DrawLine(x, y, x, y + h - 1, color);
#endif
** Function name: drawFastHLine
** Description: draw a horizontal line
void ST7735_DrawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color)
return;
w = _width - x;
#ifdef USE_SPI_DMA
ST7735_FillRectangle(x, y, w, 1, color);
#else
ST7735_DrawLine(x, y, x + w - 1, y, color);
#endif
** Function name: setRotation
** Description: rotate the screen orientation m = 0-3
void ST7735_SetRotation(uint8_t m)
_value_rotation = m % 4;
TFT_CS_L();
ST7735_WriteCommand(ST7735_MADCTL);
switch (_value_rotation)
case 0:
uint8_t d_r = (_data_rotation[0] | _data_rotation[1] | _data_rotation[3]);
ST7735_WriteData(&d_r, sizeof(d_r));
_height = ST7735_HEIGHT;
_xstart = ST7735_XSTART;
break;
case 1:
uint8_t d_r = (_data_rotation[1] | _data_rotation[2] | _data_rotation[3]);
_width = ST7735_HEIGHT;
_height = ST7735_WIDTH;
_xstart = ST7735_YSTART;
_ystart = ST7735_XSTART;
break;
case 2:
uint8_t d_r = _data_rotation[3];
break;
case 3:
uint8_t d_r = (_data_rotation[0] | _data_rotation[2] | _data_rotation[3]);
break;
TFT_CS_H();
uint8_t ST7735_GetRotation(void)
return _value_rotation;
int16_t ST7735_GetHeight(void)
return _height;
int16_t ST7735_GetWidth(void)
return _width;
字库和图片没上传,太大。最后有参考的网友GITHUB.
六,测试代码。
uint8_t r = 3;
void demoTFT(void)
ST7735_SetRotation(r);
ST7735_FillScreen(ST7735_BLACK);
for(int x = 0; x < ST7735_GetWidth(); x++)
ST7735_DrawPixel(x, 0, ST7735_WHITE);
ST7735_DrawPixel(x, ST7735_GetHeight() - 1, ST7735_WHITE);
for(int y = 0; y < ST7735_GetHeight(); y++)
ST7735_DrawPixel(0, y, ST7735_WHITE);
ST7735_DrawPixel(ST7735_GetWidth() - 1, y, ST7735_WHITE);
ST7735_DrawLine(0, 0, ST7735_GetWidth(), ST7735_GetHeight(), ST7735_WHITE);
ST7735_DrawLine(ST7735_GetWidth(), 0, 0, ST7735_GetHeight(), ST7735_WHITE);
HAL_Delay(1000);
for (int i = 0; i < ST7735_GetHeight(); i += 4)
ST7735_DrawFastHLine(0, i, ST7735_GetWidth() - 1, ST7735_WHITE);
for (int i = 0; i < ST7735_GetWidth(); i += 4)
ST7735_DrawFastVLine(i, 0, ST7735_GetHeight() - 1, ST7735_WHITE);
HAL_Delay(1000);
// Check fonts
ST7735_DrawString(0, 0, "Font_7x10, red on black, ACM32F403RET7", Font_7x10, ST7735_RED, ST7735_BLACK);
ST7735_DrawString(0, 310, "Font_11x18, ACM32F403RET7", Font_11x18, ST7735_GREEN, ST7735_BLACK);
ST7735_DrawString(0, 310+3*18, "ACM32F403", Font_16x26, ST7735_BLUE, ST7735_BLACK);
HAL_Delay(1000);
// Check colors
ST7735_DrawString(0, 0, "BLACK", Font_11x18, ST7735_WHITE, BLACK);
HAL_Delay(500);
ST7735_FillScreen(ST7735_BLUE);
ST7735_DrawString(0, 0, "BLUE", Font_11x18, ST7735_BLACK, BLUE);
HAL_Delay(500);
ST7735_FillScreen(ST7735_RED);
ST7735_DrawString(0, 0, "RED", Font_11x18, ST7735_BLACK, RED);
HAL_Delay(500);
ST7735_FillScreen(ST7735_GREEN);
ST7735_DrawString(0, 0, "GREEN", Font_11x18, ST7735_BLACK, GREEN);
HAL_Delay(500);
ST7735_FillScreen(ST7735_CYAN);
ST7735_DrawString(0, 0, "CYAN", Font_11x18, ST7735_BLACK, CYAN);
HAL_Delay(500);
ST7735_FillScreen(ST7735_MAGENTA);
ST7735_DrawString(0, 0, "MAGENTA", Font_11x18, ST7735_BLACK, MAGENTA);
HAL_Delay(500);
ST7735_FillScreen(ST7735_YELLOW);
ST7735_DrawString(0, 0, "YELLOW", Font_11x18, ST7735_BLACK, YELLOW);
HAL_Delay(500);
ST7735_FillScreen(ST7735_WHITE);
ST7735_DrawString(0, 0, "WHITE", Font_11x18, ST7735_BLACK, WHITE);
HAL_Delay(500);
// Draw circles
for (int i = 0; i < ST7735_GetHeight() / 2; i += 2)
ST7735_DrawCircle(ST7735_GetWidth() / 2, ST7735_GetHeight() / 2, i, YELLOW);
HAL_Delay(1000);
ST7735_FillTriangle(0, 0, ST7735_GetWidth() / 2, ST7735_GetHeight(), ST7735_GetWidth(), 0, RED);
HAL_Delay(1000);
ST7735_FillScreen(BLACK);
ST7735_DrawImage(0, 0, 128, 128, (uint16_t*) test_img_128x128);
HAL_Delay(1000);
r++;
七,主程序代码:
int main(void)
System_Init();
LED_GPIO_Config();
Uart_Init();
ST7735_GPIO_Init();
ST7735_Spi2_Init();
ST7735_Init();
ST7735_Backlight_On();
ST7735_DrawString(0, 0, "CSDN", Font_7x10, ST7735_RED, ST7735_BLACK);
ST7735_DrawString(0, 12, "CSDN", Font_11x18, ST7735_GREEN, ST7735_BLACK);
ST7735_DrawString(0, 32, "CSDN", Font_16x26, ST7735_BLUE, ST7735_BLACK);
while(1)
demoTFT();
Delay_ms(500);
液晶屏显示颜色对不上,没调整。参考例程和我手里液晶屏不一样。
