使用CH579做低功耗蓝牙主机。在主机例程中,获取特征值句柄的代码如下:
if ( ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP && pMsg->hdr.status == bleProcedureComplete ) || ( pMsg->method == ATT_ERROR_RSP ) ) { if ( centralSvcStartHdl != 0 ) { // Discover characteristic centralDiscState = BLE_DISC_STATE_CHAR; req.startHandle = centralSvcStartHdl; req.endHandle = centralSvcEndHdl; req.type.len = ATT_BT_UUID_SIZE; req.type.uuid[0] = LO_UINT16(TEMPPROFILE_CHAR3_UUID); req.type.uuid[1] = HI_UINT16(TEMPPROFILE_CHAR3_UUID); GATT_ReadUsingCharUUID( centralConnHandle, &req, centralTaskId ); } } 我模仿主机例程,新增了一个服务表,特征值均采用16oct,然而无法获取到特征值句柄,代码如下: if ( ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP && pMsg->hdr.status == bleProcedureComplete ) || ( pMsg->method == ATT_ERROR_RSP ) ) { if ( centralSvcStartHdl != 0 ) { // Discover characteristic centralDiscState = BLE_DISC_STATE_CHAR; req.startHandle = centralSvcStartHdl; req.endHandle = centralSvcEndHdl; req.type.len = ATT_BT_UUID_SIZE; req.type.uuid[0] = LO_UINT16(LED_CHAR2_UUID); req.type.uuid[1] = HI_UINT16(LED_CHAR2_UUID); GATT_ReadUsingCharUUID( centralConnHandle, &req, centralTaskId ); } } 但是,如果使用如下代码,只换了GATT_DiscCharsByUUID就可以了: if ( ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP && pMsg->hdr.status == bleProcedureComplete ) || ( pMsg->method == ATT_ERROR_RSP ) ) { if ( centralSvcStartHdl != 0 ) { // Discover characteristic centralDiscState = BLE_DISC_STATE_CHAR; req.startHandle = centralSvcStartHdl; req.endHandle = centralSvcEndHdl; req.type.len = ATT_BT_UUID_SIZE; req.type.uuid[0] = LO_UINT16(LED_CHAR2_UUID); req.type.uuid[1] = HI_UINT16(LED_CHAR2_UUID); GATT_DiscCharsByUUID( centralConnHandle, &req, centralTaskId ); } } 为什么啊? |
如果按照主机程序的流程会先发现handle的范围,同时已知UUID,因此可以DiscCharsByUUID,且我们自己在进行蓝牙连接和透传数据时是会修改为这个的。设置为ReadUsingCharUUID是已知UUID就可以了。
647 浏览 1 评论
CH579M+RT-Thread,RTC从Sleep模式唤醒失败是什么原因?
2967 浏览 2 评论
2454 浏览 1 评论
960浏览 2评论
760浏览 1评论
riscv-none-embed-objcopy: \'PWM_Output.elf\': No such file这个咋解决,
484浏览 1评论
610浏览 1评论
请教一下,Mounriver 编译不成功:找不到库文件,怎么整
893浏览 1评论
GMT+8, 2025-2-24 16:59 , Processed in 1.185291 second(s), Total 74, Slave 58 queries .
