高优先级的线程播放音频,低优先级的线程负责按键和显示,当按键和显示条件越加越多,而实际上都没有执行,也会影响高优先级的调用时间片。中间多加几个sleep也没用。不理解这个是什么原理,高手帮忙解释下 |
6个回答
按键处理逻辑,其中按键和显示线程优先级是21,音频接收和播放线程优先级都是19,下方有一个#if 1, 如果改成#if 0 ,播放时序就必定被打乱。实际上,AudioBox(display.ui.mode) 一直都是LCD_UI_MODE_COMMON,没有按键时不会进去其他模式,但是表现是播放时序明显变慢。
Description: KeyPad Thread entry Para: parameter form thread creation Return: void void keyPad_entry(void *parameter) { uint32_t keystate=0; rt_kprintf("Enter KeyPad Procressn"); while(1) { keystate = ~(GPIO_ISTAT(KEY_PAD_GPIO_PORT)&(KEY_PAD_ALLPIN_VALUE)) & KEY_PAD_ALLPIN_VALUE; if(keystate & KEY_PAD_ALLPIN_VALUE) { /*execute different key event function by mode*/ switch(AudioBox(display.ui.mode)) { case LCD_UI_MODE_COMMON: ProcessKeyWithCommonMode(keystate); break; case LCD_UI_MODE_EDIT: ProcessKeyWithEditMode(keystate); break; case LCD_UI_MODE_EXTERN: ProcessKeyWithExternMode(keystate); break; default: break; } /*any key will recount idle*/ AudioBox(display.ui.ui_timeout) = 0; keystate = 0; rt_thread_mdelay(180); } LockThread(); if(AudioBox(display.ui.pMenu->menuindex) != AudioBox(display.ui.changeMenu))/*Menu changed*/ { if(AudioBox(display.ui.pMenu->menuindex) == LCD_UI_MENU_PAIREDDEV_LIST) { //free paired list AudioBoxPairedDevList_t * pFree = AudioBox(btdevice.paired_list); AudioBoxPairedDevList_t * pNextFree; while(pFree !=NULL) { pNextFree = (AudioBoxPairedDevList_t *)pFree->p.next; rt_kprintf("Free Device: %srn",pFree->device.u8Name); rt_free(pFree); pFree = pNextFree; } AudioBox(btdevice.paired_num) = 0; } /*Display menu*/ AudioBox(display.ui.pMenu) = LcdUiDisplayMenu(AudioBox(display.ui.changeMenu)); /*Display external context*/ LcdUiDisplayUpdateExtContext(AudioBox(display.ui.changeMenu),TRUE); } else if(AudioBox(display.ui.changmode))/*mode changed*/ { AudioBox(display.ui.changmode) = FALSE; LcdUiDisplayUpdateExtContext(AudioBox(display.ui.pMenu->menuindex),FALSE); } else if(AudioBox(display.ui.op_change)) /*select changed +*/ { #if 0 LcdUiDisplaySelect(AudioBox(display.ui.pMenu),AudioBox(display.ui.op_value)>0,AudioBox(display.ui.op_change)); #else switch(AudioBox(display.ui.mode)) { case LCD_UI_MODE_COMMON: LcdUiDisplaySelect(AudioBox(display.ui.pMenu),AudioBox(display.ui.op_value)>0,AudioBox(display.ui.op_change)); break; case LCD_UI_MODE_EDIT: if(AudioBox(display.ui.op_value)) { AudioBox(display.ui.op_value) = FALSE; LcdUiDisplayEdititem(&AudioBox(display.ui.pEdit->pEdititem)[AudioBox(display.ui.pEdit->edit_idx)], AudioBox(display.ui.pEdit->edit_idx),LCD_CMD_INTVERT_FONT_12,AudioBox(display.ui.pEdit->value)); } else { LcdUiDisplayEditByIndex(AudioBox(display.ui.pEdit),AudioBox(display.ui.pEdit->edit_idx), AudioBox(display.ui.pEdit->pre_edit_idx)); } break; case LCD_UI_MODE_EXTERN: LcdUiDisplayExternMode(AudioBox(display.ui.pMenu->menuindex),AudioBox(display.ui.Extern.deep_level), AudioBox(display.ui.Extern.select),AudioBox(display.ui.Extern.preselect)); break; default: break; } #endif AudioBox(display.ui.op_change) = FALSE; } else { LcdUiDisplayUpdateBtState(AudioBox(display.ui.pMenu->menuindex)); } UnLockThread(); rt_thread_mdelay(20); } } |
实测就是低等级的判断逻辑或者线程数多了,就会影响高等级的处理时序,证明线程调度还不是很智能,我把msh线程删了就可以工作了
1 线程调度本来就不是智能,是规则,优先级和时间片;
2 看一下你的CPU是不是够用; 3 看一下你的低优先级任务里是不是关中断、锁任务调度了; 4 看一下你的中断是不是占用过长时间; |
感谢回复。
困扰了我快一周,最终验证测试,是因为代码空间超出了一定大小,可以执行,但是效率变得非常低。估计GD32的code area 超出之后512K就需要做重新寻址。 我验证方式是,低等级线程(按键处理)在一定的条件后直接退出。此时高等级的线程(音频接收和播放)调度依旧会受影响。当删除掉一点其他代码,就又正常了。所以是和代码大小有关,和线程调度应该没有关系 调查到这里就有点尴尬了。本身我是做蓝牙协议栈的。压缩得很辛苦才勉强够用。 各位大侠有什么好的建议吗? 下方粗体的是编译最终大小的信息。 Build started: Project: project * Using Compiler ‘V5.06 update 6 (build 750)’, folder: ‘C:Keil_v5ARMARMCCBin’ Build target ‘rt-thread_gd32f4xx’ compiling key_pad.c… applicationskey_pad.c(765): warning: #111-D: statement is unreachable rt_kprintf(“exit KeyPad Procressn”); applicationskey_pad.c(359): warning: #177-D: function “ProcessKeyWithEditMode” was declared but never referenced static void ProcessKeyWithEditMode(uint32_t keystate) applicationskey_pad.c: 2 warnings, 0 errors linking… Program Size: Code=345404 RO-data=115684 RW-data=1372 ZI-data=139068 FromELF: creating hex file… “.buildrtthread-gd32f4xx.axf” - 0 Error(s), 2 Warning(s). Build Time Elapsed: 00:00:06 Load “C:workspaceEsMcuStack_gd32450vit6buildrtthread-gd32f4xx.axf” JLink Info: Device “CORTEX-M4” selected. Set JLink Project File to “C:workspaceEsMcuStack_gd32450vit6JLinkSettings.ini” JLink Info: Device “CORTEX-M4” selected. ** |
我理解的是代码区域是映射表可以操作的地方,至于IC的内核怎么设计我就不了解了。
个人觉得应该覆盖整个Flash应该也不麻烦,可能会损失性能吧。 应该不是Cahche的概念,因为RAM只保留当前运行的函数和全局变量。运行结束之后就释放了。 看起来更像是内核管理Flash区域就只有512K,多出的也可以放代码,但是要重新做一遍寻址。这样就会额外消耗运算时间。 表现现象就是,多加点代码(即使当前不运行),也会导致音频处理线程效率变低。 |
超强算力+实时响应!米尔发布基于STM32MP25x核心板Debian系统
428 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:边缘端设备的局域网视频流传输方案
1757 浏览 0 评论
1725 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
6915 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1932 浏览 0 评论
80325 浏览 21 评论
GMT+8, 2025-3-8 12:28 , Processed in 0.625539 second(s), Total 78, Slave 62 queries .
