问题描述及复现步骤:按照wiki说明 解压sdk包,然后执行 .repo/repo/repo sync -l 正常。当执行.repo/repo/repo sync -c fatal: include |
6个回答
修复了,推送代码的时候头文件写错了,现在试一下
当执行.repo/repo/repo sync -c --no-tags 执行完毕报错 info: A new version of repo is available warning: GnuPG was not available during last "repo init" warning: Cannot automatically authenticate repo.""" error: .repo/repo/: contains uncommitted changes |
刚刚执行成功了,请问下。
我是RV1126-JD4的核心板+底板 文件系统是咱们的debain10 应该用哪一个配置项 -rw-r--r-- 1 root root 179 Mar 30 18:32 aio-rv1126-debian.mk -rw-r--r-- 1 root root 225 Mar 30 18:48 aio-rv1126-jd4-BE-45-tb-v11.mk -rw-r--r-- 1 root root 159 Mar 30 18:32 aio-rv1126-jd4-BE-45.mk -rw-r--r-- 1 root root 343 Mar 30 18:32 aio-rv1126-jd4-tb-v11.mk -rw-r--r-- 1 root root 640 Mar 30 18:32 aio-rv1126-jd4-tb.mk -rw-r--r-- 1 root root 302 Mar 30 18:32 aio-rv1126-jd4-v11.mk -rw-r--r-- 1 root root 578 Mar 30 18:32 aio-rv1126-jd4.mk -rw-r--r-- 1 root root 292 Mar 30 18:32 aio-rv1126-rkmedia-uvcc.mk -rw-r--r-- 1 root root 213 Mar 30 18:32 aio-rv1126-uvcc.mk -rw-r--r-- 1 root root 162 Mar 30 18:48 aio-rv1126-xhlpr-BE-45.mk -rw-r--r-- 1 root root 304 Mar 30 18:32 aio-rv1126-xhlpr.mk |
我尝试了 aio-rv1126-debian.mk
没有编译完成,报如下错误 Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN. ==========Start building buildroot========== TARGET_BUILDROOT_CONFIG=firefly_rv1126_rv1109 ========================================= ./build.sh: line 742: /usr/bin/time: No such file or directory ERROR: Running build_buildroot failed! ERROR: exit code 1 from line 742: /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG |
编译通过了,通过安装如下工具 apt-get install time apt-get install ca-certificates 请帮忙确认一下,我是RV1126-JD4的核心板+底板 文件系统是咱们的debain10 应该用哪一个配置项? -rw-r--r-- 1 root root 179 Mar 30 18:32 aio-rv1126-debian.mk -rw-r--r-- 1 root root 225 Mar 30 18:48 aio-rv1126-jd4-BE-45-tb-v11.mk -rw-r--r-- 1 root root 159 Mar 30 18:32 aio-rv1126-jd4-BE-45.mk -rw-r--r-- 1 root root 343 Mar 30 18:32 aio-rv1126-jd4-tb-v11.mk -rw-r--r-- 1 root root 640 Mar 30 18:32 aio-rv1126-jd4-tb.mk -rw-r--r-- 1 root root 302 Mar 30 18:32 aio-rv1126-jd4-v11.mk -rw-r--r-- 1 root root 578 Mar 30 18:32 aio-rv1126-jd4.mk -rw-r--r-- 1 root root 292 Mar 30 18:32 aio-rv1126-rkmedia-uvcc.mk -rw-r--r-- 1 root root 213 Mar 30 18:32 aio-rv1126-uvcc.mk -rw-r--r-- 1 root root 162 Mar 30 18:48 aio-rv1126-xhlpr-BE-45.mk -rw-r--r-- 1 root root 304 Mar 30 18:32 aio-rv1126-xhlpr.mk |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1005 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1184 浏览 0 评论
522 浏览 0 评论
485 浏览 0 评论
777 浏览 0 评论
GMT+8, 2025-2-24 14:27 , Processed in 0.616667 second(s), Total 48, Slave 43 queries .
