2022-04-21 RT-Thread first version
#include <rtthread.h>
#define DBG_TAG "main"
#define DBG_LVL DBG_LOG
#include <rtdbg.h>
#include <rtdevice.h> //
#include "drv_common.h"
#define LED1_PIN GET_PIN(G,7)
int main(void)
int count = 1;
rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT);
while (count++)
// LOG_D("LED is on!");
rt_pin_write(LED1_PIN, PIN_HIGH);
rt_thread_mdelay(500);
// LOG_D("LED is off!");
rt_pin_write(LED1_PIN, PIN_LOW);
return RT_EOK;
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/* * Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
rt thread studio 使用心得
1、使用device时一般要添加头文件#include ,在使用pin设备必须要添加
2、#define LED1_PIN GET_PIN(G,7),宏定义很方便,这个定义在#include “drv_common.h”,不知道为什么不放在pin设备中
3、使用LOG_D(“LED is on!”);必须包含头文件#include
4、使用线程函数必须使用#include ,没使用线程可以屏蔽
5、关于适中的配置问题:需要配置board.C中的
#define BSP_CLOCK_SOURCE ("HSE")
#define BSP_CLOCK_SOURCE_FREQ_MHZ ((int32_t)8)
第5点有待确认,新建项目时候studio也在提示说配置相关文件,我对此做了实验单纯修改上面的配置,把晶振去掉是照样可以起来的,本人小白无法通过指令获取系统时钟源是从外部还是内部时钟。为了进一步确认,我配置了cubemx,配置如下:
生成的代码参见上面代码后半部分。
