问题描述及复现步骤:请问进入到maskrom模式然后烧录固件: sudo upgrade_tool uf ITX-3588J_Android12_HDMI_220830.img Program Data in /home/zhang/.config/upgrade_tool Loading firmware.。. Support Type:RK3588 FW Ver:c.0.00 FW Time:2022-08-30 08:29:28 Loader ver:1.0b Loader Time:2022-08-29 18:15:38 Upgrade firmware ok. 固件烧录完成后,串口打印到如下信息,然后卡住不动了,可能是什么问题? DDR Version V1.07 20220412 DDR Version V1.07 20220412 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09 (Aug 29 2022 - 18:14:55) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 Card did not respond to voltage select! mmc_init: -95, time 12 spl: mmc init failed with error: -95 Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 。.. sha256(581130cddd.。.) + OK ## Checking uboot 0x00200000 。.. sha256(15714d1d95.。.) + OK ## Checking fdt 0x003284b8 。.. sha256(c07f4a4d71.。.) + OK ## Checking atf-2 0x000f0000 。.. sha256(6a00298af8.。.) + OK ## Checking atf-3 0xff100000 。.. sha256(71c3a5841b.。.) + OK ## Checking atf-4 0xff001000 。.. sha256(2301cf73be.。.) + OK ## Checking optee 0x08400000 。.. sha256(603cfbd25d.。.) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 129.433 ms |
8个回答
先确认一下你用的是roc-rk3588s-pc的机器,那烧录的是对应固件,你现在烧录ITX-3588J的固件这样是不行的哦
我用的就是3588j
我的设备也是rk3588j呀
已经验证硬件上出了问题. 更换3588J核心板就可以正常工了.
但是在测试hdmi固件和mipi固件时,发现hdmi固件没有什么问题,mipi固件接上hdmi屏幕只有中间一块有显示,两边都是黑色的,并且点击导航栏 旋屏按钮无法旋转过来,这个要怎么修改? |
这是由于dpi 的问题导致,可以修改如下
--- a/device/rockchip/rk3588/rk3588_firefly_itx_3588j_mipi/rk3588_firefly_itx_3588j_mipi.mk +++ b/device/rockchip/rk3588/rk3588_firefly_itx_3588j_mipi/rk3588_firefly_itx_3588j_mipi.mk @@ -44,7 +44,7 @@ PRODUCT_FIREFLY_NAME := MIPI # ## add Rockchip properties # -PRODUCT_PROPERTY_OVERRIDES += ro.sf.lcd_density=320 +PRODUCT_PROPERTY_OVERRIDES += ro.sf.lcd_density=160 |
我的屏幕是1920*1080 不是应该改480么?
如果使用mipi屏幕分辨率是800x1280 10.1寸 计算dpi 如下
dpi = 开根号(800x800+1280x1280) /10.1 =149.4 即dpi 可以取160 |
买的mipi屏幕没有到,还没试过mipi上显示,目前使用mipi固件接1920*1080 hdmi屏幕显示异常.
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
678 浏览 0 评论
920 浏览 1 评论
814 浏览 1 评论
2030 浏览 1 评论
3275 浏览 1 评论
GMT+8, 2024-12-24 07:39 , Processed in 0.561088 second(s), Total 51, Slave 46 queries .
