描述
W50267ASZ5_sstc_ctrl_gerber SSTC 控制板具有以下接口:
特征:
物料清单: 项目 数量 参考值 LibPart 封装 C1 100n 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C2 100n 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C3 100n 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C4 100n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C5 1u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm C6 1n 设备:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C7 100p 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C8 100n 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C9 100n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C10 1u 设备:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C11 1u 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C12 1u 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C13 1u 设备:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C14 1000u 器件:C_Polarized Capacitor_THT:CP_Radial_D12.5mm_P5.00mm C15 1u 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C16 1u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm C17 100u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm C18 1n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C19 100n 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C20 1u 器件:C 电容_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm D1 1N4148 器件:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D2 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D3 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D4 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D5 LED 设备:LED LED_THT:LED_D3.0mm D6 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D7 1N4148 器件:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D8 1N4007 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D9 1N4007 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D10 1N4007 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D11 1N4007 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D12 LED 设备:LED LED_THT:LED_D3.0mm D13 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D14 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D15 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D16 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D17 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D18 1N4148 二极管:1N4148 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D19 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D20 1.5KExxA 二极管:1.5KExxA 二极管_THT:D_DO-201AE_P15.24mm_Horizontal D21 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal H1 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 H2 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 H3 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 H4安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 IC1 UCC37321 UCC37321:UCC37321 Package_DIP:DIP-8_W7.62mm_Longpads IC2 UCC37322 UCC37322:UCC37322 封装_DIP:DIP-8_W7.62mm_LongPads J1 初级电流感应变压器连接器:Screw_Terminal_01x02 端子块:TerminalBlock_bornier-2_P5.08mm J2 热敏电阻连接器:Screw_Terminal_01x02 TerminalBlock:TerminalBlock_bornier-2_P5.08mm J3 GDT 连接器:Screw_Terminal_01x02 端子块:TerminalBlock_bornier-2_P5.08mm J4 反馈感应变压器连接器:Screw_Terminal_01x02 TerminalBlock:TerminalBlock_bornier-2_P5.08mm J5 +12V 连接器:Screw_Terminal_01x02 接线端子:TerminalBlock_bornier-2_P5.08mm JP1 enable_pin Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP2 假 IC 禁用 Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP3 interrupter_A Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP4 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP5 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP6 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP7 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP8 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP9 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP10 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP11 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm L1 16 - 42uH 器件:L Inductor_THT:L_Axial_L6.6mm_D2.7mm_P10.16mm_Horizontal_Vishay_IM-2 R1 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R2 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R3 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R4 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R5 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R6 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R7 5 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R9 560 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R10 470 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R12 10k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R15 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R16 1k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R17 470 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R19 100 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R20 2,2k 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal R21 5 设备:R 电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal RV1 10k 设备:R_Potentiometer Potentiometer_THT:Potentiometer_Bourns_3296W_Vertical RV2 R_Potentiometer 设备:R_Potentiometer Potentiometer_THT:Potentiometer_Bourns_3296W_Vertical U1 L78L05_TO92 Regulator_Linear:L78L05_TO92 Package_TO_SOT_THT:TO-92_Inline U2 40106 4xxx:40106 Package_DIP:DIP-14_W7.62mm_LongPads U3 74LS74 74xx:74LS74 封装_DIP:DIP-14_W7.62mm_LongPads U4 DS1233D-5+T&R DS1233D-5_T_R:DS1233D-5+T&R DS1233D-5_T_R:TO92269P495H695-3 U5 LM393 比较器:LM393 Package_DIP:DIP-8_W7.62mm_LongPads U6 SFH-551/1-1V custom_parts:SFH-551{斜线}1-1V custom_parts:SFH551_1-1V PCB
1396 浏览 1 评论
基于FT600Q芯片 的USB3.0设计,为什么连接PC后设备无法识别?
1305 浏览 1 评论
1106 浏览 0 评论
大佬们 运放电路前一级的放大器无论输入多少 输出都是1.58v
1638 浏览 4 评论
1554 浏览 1 评论
GMT+8, 2025-1-26 01:03 , Processed in 0.398731 second(s), Total 37, Slave 28 queries .
