描述
W50267ASZ7_sstc_350V_gerber 固态特斯拉线圈 230V 整流板,带有平滑电容器、保险丝和 NTC,用于限制浪涌电流。它应该提供+325V。 物料清单 项目 数量 参考值 LibPart 封装 C1 1000u 器件:C_Polarized Capacitor_THT:CP_Radial_D12.5mm_P5.00mm C2 1000u 器件:C_Polarized Capacitor_THT:CP_Radial_D12.5mm_P5.00mm C3 10u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm C4 100n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C5 100n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm C6 10u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm D1 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizontal D2 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizontal D3 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizontal D4 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizontal D5 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D6 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizontal D7 LED 设备:LED LED_THT:LED_D3.0mm F1 保险丝装置:保险丝保险丝:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open F2 保险丝装置:保险丝保险丝:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open H1 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 H2 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 H3 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 H4安装孔机械:安装孔安装孔:安装孔_4.3mm_M4 J1 Conn_01x03_Male Connector:Conn_01x03_Male TerminalBlock:TerminalBlock_bornier-3_P5.08mm J2 Conn_01x02_Male Connector:Conn_01x02_Male TerminalBlock:TerminalBlock_bornier-2_P5.08mm JP1 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2pads_Pitch2.54mm_Drill0.8mm JP2 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm JP3 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm R1 R设备:R电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal U1 BV_EI_382_1194 custom_parts:BV_EI_382_1194 custom_parts:BV EI 382 1994 U2 BV_EI_382_1194 custom_parts:BV_EI_382_1194 custom_parts:BV EI 382 1994 U3 LM7812_TO220 Regulator_Linear:LM7812_TO220 Package_TO_SOT_THT:TO-220-3_Vertical PCB
GMT+8, 2025-1-11 03:05 , Processed in 0.544050 second(s), Total 72, Slave 52 queries .
