目前正在学习ARMv8 Arch Ref Manual. D1.10.2 Exception vectors有点疑惑: Table D1-6 定义了一个Vector Table应该具有的items 我们假定一个ARMv8 SOC实现了4个EL:EL0 / EL1 / EL2 / EL3 根据ARMv8 ARM手册:每一个EL,都有自己对应的Vector Table. 那么: EL0 / EL1 / EL2 / EL3 :它们各自的Vector Table,应该是什么样的? 比如: (1) EL0的Vector Table:应该有2个Block : Current Exception level with SP_EL0 Current Exception level with SP_ELx, x>0 (2) EL1的Vector Table:应该有4个Block : Current Exception level with SP_EL0 Current Exception level with SP_ELx, x>0 EL0 that is using AARCH64 EL0 that is using AARCH32 我的理解对吗? |
EL0 does not have a vector table. Only EL1, EL2 and EL3 have vector tables. The location is set by VBAR_EL1, VBAR_EL2 and VBAR_EL3 respectively.
Each vector table has the same format, i.e. 16 entries (1 entry = 128 bytes) grouped into 4 blocks. Starting from the lowest offset, each block is used for exceptions taken from: Current Exception level with SP_EL0 Current Exception level with SP_ELx, x>0. Lower Exception level, where the implemented level immediately lower than the target level is using AArch64 Lower Exception level, where the implemented level immediately lower than the target level is using AArch32 Consider an IRQ from an AArch32 application (EL0) running on an AArch64 OS (EL1), being handled by an AArch64 hypervisor (EL2). In this case, the exception will be "from AArch32", but the hypervisor must save all the AArch64 states, as they may contain active values for the OS. Therefore, the exception entry for this case would be: VBAR_EL2 + 0x480 |
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB转网络
456 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB摄像头
484 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之4G
621 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之wifi
1695 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB_OTG
1015 浏览 0 评论
GMT+8, 2025-3-13 13:20 , Processed in 0.793415 second(s), Total 71, Slave 55 queries .
