在添加了lwgps后,测试用例使用不了,有同学弄过这一块吗?我的怎么就是不行呢…. 我用的是和芯星通的GPS芯片。 //***************************************************************************** // file : lwgps2rtt.c // porting lwgps to rt-thread // // Change Logs: // Date Author Note // 2020/09/05 Cheney First draft version // 2020/09/13 Cheney 1. Update the comments. // 2. Support gps info query interface. // 2020/10/10 Cheney Support macros LWGPS_CFG_STATUS // 2020/12/15 Cheney Configure the uart before using it. // //***************************************************************************** //***************************************************************************** // //! \addtogroup lwgps //! @{ // //***************************************************************************** #include <rtthread.h> #include <rtdevice.h> #include <board.h> #include "lwgps.h" #ifndef GPS_MODULE_BAUD_RATE #define GPS_MODULE_BAUD_RATE BAUD_RATE_9600 #endif static lwgps_t h_lwgps; static rt_device_t serial = RT_NULL; static struct rt_semaphore rx_sem; static rt_thread_t lwgps_tid = RT_NULL; static rt_mutex_t lwgps_mutex = RT_NULL; /**
*/ static rt_err_t uart_input(rt_device_t dev, rt_size_t size) {
} #if LWGPS_CFG_STATUS == 1 void lwgps_process_cbk(lwgps_statement_t res) {
} #endif /**
*/ static void lwgps_thread_entry(void *parameter) {
#else
// rt_kprintf("Valid status: %d\r\n", h_lwgps.is_valid); // rt_kprintf("Latitude: %f degrees\r\n", h_lwgps.latitude); // rt_kprintf("Longitude: %f degrees\r\n", h_lwgps.longitude); // rt_kprintf("Altitude: %f meters\r\n", h_lwgps.altitude); #endif
*/ void lwgps2rtt_get_gps_info(lwgps_t *gps_info) {
*/ void lwgps2rtt_init(void) {
*/ void lwgps2rtt_deinit(void) {
} INIT_APP_EXPORT(lwgps2rtt_init); #include <rtthread.h> #define DBG_TAG "main" #define DBG_LVL DBG_LOG #include <rtdbg.h> #include "lwgps/lwgps.h" lwgps_t gps_info; int main(void) {
} 测试打印如图所示 |
lwgps_process(&h_lwgps, &ch, 1); 一个字节字符就想解析出来信息?
我也看到了,他是一个字节,具体的程序解析源码我没有去看,我现在修改好了。
1039 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
3425 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1465 浏览 0 评论
2146 浏览 0 评论
1640 浏览 0 评论
75318 浏览 21 评论
GMT+8, 2024-12-28 10:34 , Processed in 0.546458 second(s), Total 70, Slave 55 queries .
