扫一扫,分享给好友
出错信息显示容量大于4GB的flash不支持。
既然报错中显示不支持这个flash了。去换一个小容量的flash试试吧
还是WINBOND的flash好
1.参考芯片手册和RT其他的nor flash的信息,在sfud_flash_def.h列表中添加支持该芯片。
2.添加成功后再试一下呢,nm128的话,容量应该没有4G那么大,估计就算芯片不支持的原因。 |
是不是需要自己添加这个Flash的型号。
rt-thread/components/drivers/spi/sfud/inc/sfud_flash_def.h #ifdef SFUD_USING_FLASH_INFO_TABLE /* SFUD supported flash chip information table. If the flash not support JEDEC JESD216 standard, * then the SFUD will find the flash chip information by this table. You can add other flash to here then * notice me for update it. The configuration information name and index reference the sfud_flash_chip structure. * | name | mf_id | type_id | capacity_id | capacity | write_mode | erase_gran | erase_gran_cmd | */ #define SFUD_FLASH_CHIP_TABLE { {"AT45DB161E", SFUD_MF_ID_ATMEL, 0x26, 0x00, 2L*1024L*1024L, SFUD_WM_BYTE|SFUD_WM_DUAL_BUFFER, 512, 0x81}, {"W25Q40BV", SFUD_MF_ID_WINBOND, 0x40, 0x13, 512L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"W25Q16BV", SFUD_MF_ID_WINBOND, 0x40, 0x15, 2L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"W25Q64CV", SFUD_MF_ID_WINBOND, 0x40, 0x17, 8L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"W25Q64DW", SFUD_MF_ID_WINBOND, 0x60, 0x17, 8L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"W25Q128BV", SFUD_MF_ID_WINBOND, 0x40, 0x18, 16L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"W25Q256FV", SFUD_MF_ID_WINBOND, 0x40, 0x19, 32L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"SST25VF016B", SFUD_MF_ID_SST, 0x25, 0x41, 2L*1024L*1024L, SFUD_WM_BYTE|SFUD_WM_AAI, 4096, 0x20}, {"M25P32", SFUD_MF_ID_MICRON, 0x20, 0x16, 4L*1024L*1024L, SFUD_WM_PAGE_256B, 64L*1024L, 0xD8}, {"M25P80", SFUD_MF_ID_MICRON, 0x20, 0x14, 1L*1024L*1024L, SFUD_WM_PAGE_256B, 64L*1024L, 0xD8}, {"M25P40", SFUD_MF_ID_MICRON, 0x20, 0x13, 512L*1024L, SFUD_WM_PAGE_256B, 64L*1024L, 0xD8}, {"EN25Q32B", SFUD_MF_ID_EON, 0x30, 0x16, 4L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"GD25Q64B", SFUD_MF_ID_GIGADEVICE, 0x40, 0x17, 8L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"GD25Q16B", SFUD_MF_ID_GIGADEVICE, 0x40, 0x15, 2L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"S25FL216K", SFUD_MF_ID_CYPRESS, 0x40, 0x15, 2L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"S25FL032P", SFUD_MF_ID_CYPRESS, 0x02, 0x15, 4L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"A25L080", SFUD_MF_ID_AMIC, 0x30, 0x14, 1L*1024L*1024L, SFUD_WM_PAGE_256B, 4096, 0x20}, {"F25L004", SFUD_MF_ID_ESMT, 0x20, 0x13, 512L*1024L, SFUD_WM_BYTE|SFUD_WM_AAI, 4096, 0x20}, {"PCT25VF016B", SFUD_MF_ID_SST, 0x25, 0x41, 2L*1024L*1024L, SFUD_WM_BYTE|SFUD_WM_AAI, 4096, 0x20}, } #endif /* SFUD_USING_FLASH_INFO_TABLE */ |
按照正点原子的例子,NM系列的厂商ID是这个,应该是自己添加一下厂商ID和大小的信息到这个SFUD_FLASH_CHIP_TABLE里面就行。不过我是自己把NM25Q128拆下来了,自己换了一块W25Q128
#define NM25Q80 0X5213 #define NM25Q16 0X5214 #define NM25Q32 0X5215 #define NM25Q64 0X5216 #define NM25Q128 0X5217 #define NM25Q256 0X5218 |
诺存的联系我 可以提供原厂威廉希尔官方网站
支持
AI模型部署边缘设备的奇妙之旅:边缘端设备的局域网视频流传输方案
1749 浏览 0 评论
1663 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
6904 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1924 浏览 0 评论
5530 浏览 0 评论
80106 浏览 21 评论
GMT+8, 2025-3-4 14:39 , Processed in 0.572083 second(s), Total 48, Slave 43 queries .
