描述
使用 Nodemcu 的基于 WiFi 的交流调光器 此 PCB 布局适用于使用 esp8266 的交流调光器。该项目是基于 WIFI 的交流调光器,我们可以在其中控制为电器提供的电源。 这个怎么运作: 我们正在使用零交叉检测器来检测交流电源线的零交叉。一旦我们使用过零检测器检测到过零,然后打开双向可控硅开关所需的时间。 以下是本项目使用的材料 cl - CPl:电容器_THT:CP_Radial_DS.0mm_P2.50mm c2 - C:电容器_THT:C_Disc_D3.0mm_W2.0mm_P2.50mm c3 - CPl:电容器_THT:CP_Radial_DS.Omm_P2.50mm c4 - C:电容器_THT:C_Disc_D3.0mm_W2.0mm_P2.50mm Dl - 1N4007 : Diode_THT:D_DO-41_SOD81_P10.1émm 水平 D2 - 1N4007 : Diode_THT:D_DO-41_SOD81_P10.1émm 水平 D3 - 1N4007 : Diode_THT:D_DO-41_SOD81_P10.1émm 水平 Da - 1N4007 : Diode_THT:D_DO-41_SOD81_P10.1émm 水平 DS - LED : LED _SMD:LED 120€_321éMetric_Padl.42x1.7S5mm_HandSolder dl - UART:连接器 _PinHeader_2.54mm:PinHeader_1x0S_P2.S4mm_Vertical J2 - AC_IN : TerminalBlock:TerminalBlock_bornier-2_P5.08mm J3 - 负载:端子块:TerminalBlock_bornier-2_P5.08mm MH1 - 安装孔:安装孔:MountingHole_3.2mm_M3_IS014580 MH2 - 安装孔:安装孔:MountingHole_3.2mm_M3_IS014580 MH3 - 安装孔:安装孔:MountingHole_3.2mm_M3_IS014580 MH4 - 安装孔:安装孔:安装孔_ 3.2mm _M3_1S014580 Ql - BI136-S500:Package_TO_SOT_THT:T0-220-3_Vertical Rl - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder R2 - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder R3 - R:电阻器_SMD:R_1206_321é6Metric_Padl.42x1.75mm_HandSolder R4 - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder RS - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder RE - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder R7 - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder RS - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder RS - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder R1O - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder SW1 - 闪光灯:Button_Switch_THT:SW_PUSH_émm_HSmm SW2 - 重置:Button_Switch_THT:SW_PUSH_émm_HSmm Ul - MOC3021M : Package_DIP:DIP-€_W7.62mm_Longpads U2 - 4N25 : Package_DIP:DIP-€_W7.é2mm U3 - 1M1117-3.3:Package_TO_SOT_SMD:SOT-223-3_TabPin2 U4 - HLK-PMOS : Power_Supply:HLK-PMOS 这是代码链接 https://github.com/nassir-malik/IOT-AC-Light-Dimmer-With-Alexa/tree/master/Part%20%23%201/robodyn_dimmer PCB 代码 https://github.com/nassir-malik/IOT-AC-Light-Dimmer-With-Alexa/tree/master/Part%20%23%201/robodyn_dimmer
676 浏览 0 评论
503 浏览 0 评论
2142 浏览 3 评论
说是一款高频高压三相channel transmitter专业词我不知道怎么翻译
1723 浏览 1 评论
电路分析:为什么R6处输出电压为8V,R6和Q1拆掉是这样?
923 浏览 1 评论
GMT+8, 2024-9-22 13:30 , Processed in 0.726390 second(s), Total 69, Slave 49 queries .
