#define SBP_PERIODIC_EVT_PERIOD 1600
// How often to perform read rssi event #define SBP_READ_RSSI_EVT_PERIOD 6400 // Parameter update delay //#define SBP_PARAM_UPDATE_DELAY 100 #define SBP_PARAM_UPDATE_DELAY 0 // What is the advertising interval when device is discoverable (units of 625us, 80=50ms) #define DEFAULT_ADVERTISING_INTERVAL 160 // Limited discoverable mode advertises for 30.72s, and then stops // General discoverable mode advertises indefinitely #define DEFAULT_DISCOVERABLE_MODE GAP_ADTYPE_FLAGS_GENERAL // Minimum connection interval (units of 1.25ms, 6=7.5ms) //#define DEFAULT_DESIRED_MIN_CONN_INTERVAL 6 #define DEFAULT_DESIRED_MIN_CONN_INTERVAL 10 // Maximum connection interval (units of 1.25ms, 100=125ms) //#define DEFAULT_DESIRED_MAX_CONN_INTERVAL 100 #define DEFAULT_DESIRED_MAX_CONN_INTERVAL 10 // Slave latency to use parameter update #define DEFAULT_DESIRED_SLAVE_LATENCY 0 // Supervision timeout value (units of 10ms, 100=1s) #define DEFAULT_DESIRED_CONN_TIMEOUT 10 |
322 浏览 1 评论
CH579M+RT-Thread,RTC从Sleep模式唤醒失败是什么原因?
2784 浏览 2 评论
2289 浏览 1 评论
200浏览 2评论
297浏览 2评论
374浏览 2评论
276浏览 2评论
CH579芯片用WCH-Link烧写后部分程序失效如何恢复?
289浏览 2评论
GMT+8, 2024-9-20 19:43 , Processed in 1.094267 second(s), Total 42, Slave 37 queries .
