1 前言
本章介绍下使用mqtt示例发送消息。
2 代码
2.1 示例bug
官方示例: https://gitee.com/Lockzhiner-Ele ... iot_mqtt/iot_mqtt.c
这里有一个bug,不知道后续有没有改回来,注意一下。
2.2 main.c
- * Copyright (c) 2022 FuZhou Lockzhiner Electronic Co., Ltd. All rights reserved.
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- #include "los_tick.h"
- #include "los_task.h"
- #include "los_config.h"
- #include "los_interrupt.h"
- #include "los_debug.h"
- #include "los_compiler.h"
- #include "lz_hardware.h"
- #include "config_network.h"
- #define MAIN_TAG "MAIN"
- int DeviceManagerStart();
- void IotInit(void);
- // void NFC_example2();
- // void uart_example();
- void iot_mqtt_example();
- Function : main
- Description : Main function entry
- Input : None
- Output : None
- Return : None
- LITE_OS_SEC_TEXT_INIT int Main(void)
- int ret;
- LZ_HARDWARE_LOGD(MAIN_TAG, "%s: enter ...", __func__);
- HalInit();
- ret = LOS_KernelInit();
- if (ret == LOS_OK) {
- IotInit();
- printf("n");
- printf("----------- test start -----------n");
- // task_example2();
- // nfc_example2();
- iot_mqtt_example();
- // uart_example();
- printf("----------- test end -----------n");
- printf("n");
- OHOS_SystemInit();
- ClkDevInit();
- /* 开启驱动管理服务 */
- //DeviceManagerStart();
- // ExternalTaskConfigNetwork();
- LZ_HARDWARE_LOGD(MAIN_TAG, "%s: LOS_Start ...", __func__);
- LOS_Start();
- while (1) {
- __asm volatile("wfi");
复制代码
PS:ExternalTaskConfigNetwork需要在main中先注释掉。
2.3 更改wifi账号和密码
lockzhiner-rk2206-openh ARMony3.0ltsdevicerockchiprk2206sdk_liteosboardsrcconfig_network.c
2.4 MQTT账号与密码设置
初始化
- typedef struct
- /** The eyecatcher for this structure. must be MQTC. */
- char struct_id[4];
- /** The version number of this structure. Must be 0 */
- int struct_version;
- /** Version of MQTT to be used. 3 = 3.1 4 = 3.1.1
- unsigned char MQTTVersion;
- MQTTString clientID;
- unsigned short keepAliveInterval;
- unsigned char cleansession;
- unsigned char willFlag;
- MQTTPacket_willOptions will;
- MQTTString username;
- MQTTString password;
- } MQTTPacket_connectData;
- #define MQTTPacket_connectData_initializer { {'M', 'Q', 'T', 'C'}, 0, 4, {NULL, {0, NULL}}, 60, 1, 0,
- MQTTPacket_willOptions_initializer, {NULL, {0, NULL}}, {NULL, {0, NULL}} }
复制代码
仿照着添加mqtt账号和密码
这里使用的是示例的代码。增加账号和密码即可
- begin:
- printf("NetworkConnect...n");
- rc = NetworkConnect(&network, MQTT_HOST, MQTT_PORT);
- printf("MQTTClientInit...n");
- MQTTClientInit(&client, &network, 2000, sendBuf, sizeof(sendBuf), readBuf, sizeof(readBuf));
- clientId.cstring = "RK2206-youkai";
- data.clientID = clientId;
- data.willFlag = 0;
- data.MQTTVersion = 3;
- data.keepAliveInterval = 0;
- data.cleansession = 1;
- // youkai add
- MQTTString username_t = MQTTString_initializer;
- username_t.cstring = "mqtt_id";
- MQTTString password_t = MQTTString_initializer;
- password_t.cstring = "mqtt_pw";
- data.password = password_t;
- data.username = username_t;
复制代码
2.5 发送接口
接口比较简单,MQTTPublish用于发送消息,其中IOT_MQTT也就是消息本身,可以注意服务器的接收内容。
- while (1)
- sprintf(payload, "publish test");
- message.qos = 2;
- message.retained = 0;
- message.payload = payload;
- message.payloadlen = strlen(payload);
- if ((rc = MQTTPublish(&client, "IOT_MQTT", &message)) != 0){
- printf("Return code from MQTT publish is %dn", rc);
- NetworkDisconnect(&network);
- MQTTDisconnect(&client);
- goto begin;
- LOS_Msleep(5000);
复制代码
3 结果
小凌派log
服务器log
