概述
RK3588双系统启动流程如下图 uboot根据按键来识别要启动的系统,这里可以使用拨码开关来代替。 uboot在加载分区的时根据分区名字来区分加载android或者linux的分区,所以在linux和android分区表中需要用"_android"字段来区分。 硬件环境 基于RK3588 EVB1开发板实现,系统切换按键是ESC 返回键 软件环境 RK3588 Android12 SDK + RK3588 linux Debian系统 要求 Android和linux的固件的代码uboot和rkbin部分需要一致,因为uboot和loader是共用一份 uboot需要额外补丁,可以通过RK的redmine获取 代码修改 uboot引导不同的系统 在uboot打上支持双系统的补丁0003-disk-part-Support-get-partition-name-suffix-from-env.patch,该补丁可以通过RK的redmine系统获取。 设置切换按键及分区名称下标 u-boot$ //配置BACK按键做为切换按键,这里使用adc采样,设置按键对应的adc值 diff --git a/arch/arm/dts/rk3588-evb.dts b/arch/arm/dts/rk3588-evb.dts index ad750d5b74..b6218fd742 100644 --- a/arch/arm/dts/rk3588-evb.dts +++ b/arch/arm/dts/rk3588-evb.dts @@ -27,5 +27,12 @@ label = "volume up"; press-threshold-microvolt = <1750>; }; + + back-key { + u-boot,dm-pre-reloc; + linux,code = + label = "back"; + press-threshold-microvolt = <1235000>; + }; }; }; //配置按键切换,在开机是检测到按键按下就从boot_android分区引导boot启动,即启动android系统,否则引导linux的boot,启动linux系统 diff --git a/arch/arm/mach-rockchip/rk3588/rk3588.c b/arch/arm/mach-rockchip/rk3588/rk3588.c index a8efc4f9b4..e7b94001c1 100644 --- a/arch/arm/mach-rockchip/rk3588/rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/rk3588.c @@ -4,6 +4,7 @@ * SPDX-License-Identifier: GPL-2.0+ */ #include +#include #include #include #include @@ -940,3 +941,18 @@ int rk_board_fdt_fixup(const void *blob) return 0; } + +int board_early_init_r(void) +{ + + printf("board_early_init_r "); + if (key_is_pressed(key_read(KEY_BACK))) { + env_set("part_suffix", "_android"); + printf("Part suffix: _android "); + } else { + env_set("part_suffix", NULL); + } + + return 0; +} + diff --git a/configs/rk3588_defconfig b/configs/rk3588_defconfig index fd6c9114f0..da7ca13626 100644 --- a/configs/rk3588_defconfig +++ b/configs/rk3588_defconfig @@ -223,3 +223,4 @@ CONFIG_RK_AVB_LIBAVB_USER=y CONFIG_OPTEE_CLIENT=y CONFIG_OPTEE_V2=y CONFIG_OPTEE_ALWAYS_USE_SECURITY_PARTITION=y +CONFIG_BOARD_EARLY_INIT_R=y diff --git a/drivers/input/key-uclass.c b/drivers/input/key-uclass.c index 1fe9f2c267..0db67fb251 100644 --- a/drivers/input/key-uclass.c +++ b/drivers/input/key-uclass.c @@ -39,6 +39,7 @@ uint64_t key_timer(uint64_t base) static int key_adc_event(struct dm_key_uclass_platdata *uc_key, int adcval) { + KEY_ERR("adcval=%d,max=%d,min=%d ",adcval, uc_key->max, uc_key->min); return (adcval <= uc_key->max && adcval >= uc_key->min) ? KEY_PRESS_DOWN : KEY_PRESS_NONE; } 修改parameter分区表 双系统的分区表使用同一个,需要把linux和android的分区都加上去,如果两个系统分区名称有重复的,需要把android的分区名后面加_android来区分。具体如下: FIRMWARE_VER: 12.0 MACHINE_MODEL: rk3588_s MACHINE_ID: 007 MANUFACTURER: rockchip MAGIC: 0x5041524B ATAG: 0x00200800 MACHINE: rk3588_s CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 TYPE: GPT CMDLINE:mtdparts=rk29xxnand:0x00002000@0x00002000(security),0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc_android),0x00002000@0x0000a000(dtbo),0x00000800@0x0000c000(vbmeta),0x00014000@0x0000c800(boot_android),0x00030000@0x00020800(recovery_android),0x000c0000@0x00050800(backup_android),0x000c0000@0x00110800(cache),0x00008000@0x001d0800(metadata),0x00000800@0x001d8800(baseparameter),0x00614000@0x001d9000(super),0x800000@0x007ed000(userdata_android),0x00002000@0x00fed000(misc),0x00020000@0x00fef000(boot),0x00040000@0x0100f000(recovery),0x00010000@0x0104f000(backup),0x01c00000@0x0105f000(rootfs),0x00040000@0x02c5f000(oem),-@0x02c9f000(userdata:grow) uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9 ** 其中: uboot分区是linux和android共用的,其他分区都是独立的; Android的misc、boot、 recovery、 backup、 userdata分区因为跟linux重复了所以需要改为misc_android boot_android recovery_android backup_android userdata_android 修改Android系统的fstab 由于Android的分区名改了,所以需要fstab里面对应修改挂在的路径,如下: fstab的修改 device/rockchip/common: diff --git a/scripts/fstab_tools/fstab.in b/scripts/fstab_tools/fstab.in index 2ec6c265..c5098a0c 100755 --- a/scripts/fstab_tools/fstab.in +++ b/scripts/fstab_tools/fstab.in @@ -6,10 +6,10 @@ ${_block_prefix}system /system ext4 ro,barrier=1 ${_flags_vbmeta},first_stage ${_block_prefix}vendor /vendor ext4 ro,barrier=1 ${_flags},first_stage_mount ${_block_prefix}odm /odm ext4 ro,barrier=1 ${_flags},first_stage_mount -/dev/block/by-name/boot /boot emmc defaults ${_flags_chained}first_stage_mount +/dev/block/by-name/boot_android /boot emmc defaults ${_flags_chained}first_stage_mount /dev/block/by-name/cache /cache ext4 noatime,nodiratime,nosuid,nodev,noauto_da_alloc,discard wait,check /dev/block/by-name/metadata /metadata ext4 nodev,noatime,nosuid,discard,sync wait,formattable,first_stage_mount,check -/dev/block/by-name/misc /misc emmc defaults defaults +/dev/block/by-name/misc_android /misc emmc defaults defaults /devices/platform/*usb* auto vfat defaults voldmanaged=usb:auto @@ -23,6 +23,6 @@ ${_block_prefix}odm /odm ext4 ro,barrier=1 ${_flags},first_stage_mount # For sdmmc /devices/platform/${_sdmmc_device}/mmc_host* auto auto defaults voldmanaged=sdcard1:auto # Full disk encryption has less effect on rk3326, so default to enable this. -/dev/block/by-name/userdata /data f2fs noatime,nosuid,nodev,discard,reserve_root=32768,resgid=1065 latemount,wait,check,fileencryption=aes-256-xts:aes-256-cts:v2+inlinecrypt_optimized,keydirectory=/metadata/vold/metadata_encryption,quota,formattable,reservedsize=128M,checkpoint=fs +/dev/block/by-name/userdata_android /data f2fs noatime,nosuid,nodev,discard,reserve_root=32768,resgid=1065,fsync_mode=nobarrier latemount,wait,check,fileencryption=aes-256-xts:aes-256-cts:v2+inlinecrypt_optimized,keydirectory=/metadata/vold/metadata_encryption,quota,formattable,reservedsize=128M,checkpoint=fs # for ext4 #/dev/block/by-name/userdata /data ext4 discard,noatime,nosuid,nodev,noauto_da_alloc,data=ordered,user_xattr,barrier=1 latemount,wait,formattable,check,fileencryption=software,quota,reservedsize=128M,checkpoint=block recovery.fstab的修改 对应的recovery的fstab也要修改,修改产品目录下的recovery.fstab device/rockchip/rk3588$ diff --git a/rk3588_s/recovery.fstab b/rk3588_s/recovery.fstab index f7843a1..6a82ccc 100644 --- a/rk3588_s/recovery.fstab +++ b/rk3588_s/recovery.fstab @@ -9,20 +9,20 @@ /dev/block/by-name/system_ext /system_ext ext4 defaults defaults /dev/block/by-name/vendor_dlkm /vendor_dlkm ext4 defaults defaults /dev/block/by-name/odm_dlkm /odm_dlkm ext4 defaults defaults /dev/block/by-name/cache /cache ext4 defaults defaults /dev/block/by-name/metadata /metadata ext4 defaults defaults -/dev/block/by-name/userdata /data f2fs defaults defaults +/dev/block/by-name/userdata_android /data f2fs defaults defaults /dev/block/by-name/cust /cust ext4 defaults defaults /dev/block/by-name/custom /custom ext4 defaults defaults /dev/block/by-name/radical_update /radical_update ext4 defaults defaults -/dev/block/by-name/misc /misc emmc defaults defaults +/dev/block/by-name/misc_android /misc emmc defaults defaults /dev/block/by-name/uboot /uboot emmc defaults defaults /dev/block/by-name/charge /charge emmc defaults defaults /dev/block/by-name/resource /resource emmc defaults defaults /dev/block/by-name/parameter /parameter emmc defaults defaults -/dev/block/by-name/boot /boot emmc defaults defaults -/dev/block/by-name/recovery /recovery emmc defaults defaults -/dev/block/by-name/backup /backup emmc defaults defaults +/dev/block/by-name/boot_android /boot emmc defaults defaults +/dev/block/by-name/recovery_android /recovery emmc defaults defaults +/dev/block/by-name/backup_android /backup emmc defaults defaults /dev/block/by-name/frp /frp emmc defaults defaults /dev/block/by-name/trust /trust emmc defaults defaults /dev/block/by-name/baseparamer /baseparamer emmc defaults defaults Linux系统固件 linux系统的固件软件不需要修改,可以直接用编译好的固件 固件烧写 固件需要烧写linux和android的固件,如下图,可以直接右键导入上面修改好的parameter.txt文件,然后删除不需要的烧写固件分区即可。 注意:uboot、loader、parameter这三个是共用的,只需要烧一份即可。 验证 固件烧写完成后第一次默认开机会从linux系统启动,linux正常启动后可以按住ESC按键,然后重启系统,ESC要一直按住到android系统启动完成。 原作者:loitawu |
3 条评论
4个回答
谢谢分析,收获颇丰!
感觉很赞。好文
这边有专业团队给您提供申请专利的方案开发,专家给您布局,薇newcharacters】与其临渊羡鱼,不如退而结网。
看啦文章有收获,赞
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
2420 浏览 0 评论
2778 浏览 1 评论
2268 浏览 1 评论
3597 浏览 1 评论
4355 浏览 1 评论
GMT+8, 2025-1-23 09:14 , Processed in 0.593746 second(s), Total 80, Slave 64 queries .
