qt5软虚拟键盘使用
.pro文件修改 qt5要使用虚拟键盘只能使用qml布局,不然无法使用 工程文件.pro 增加 DEFINES += QT_QML QT += qml quick RESOURCES += demo.qrc OTHER_FILES += virkey.qml demo.qrc中增加virkey.qml qml布局文件 virkey.qml文件内容如下 import QtQuick 2.0 import QtQuick.Window 2.2 import QtQuick.VirtualKeyboard 2.1 Window { visible: true width: 1024 height: 600 Textinput { text: "11111111111" font.pointSize: 20 anchors { left: parent.left; right: parent.right; margins: 12 } } TextEdit { anchors.centerIn: parent width: 500 height: 200 text: "+++test+++" focus: true color: "blue" font.pointSize: 20 readOnly: false } InputPanel { id: inputPanel z: 99 y: parent.height anchors.left: parent.left anchors.right: parent.right states: State { name: "visible" /* The visibility of the InputPanel can be bound to the Qt.inputMethod.visible property, but then the handwriting input panel and the keyboard input panel can be visible at the same time. Here the visibility is bound to InputPanel.active property instead, which allows the handwriting panel to control the visibility when necessary. */ when: inputPanel.active PropertyChanges { target: inputPanel y: parent.height - inputPanel.height } } transitions: Transition { from: "" to: "visible" reversible: true ParallelAnimation { NumberAnimation { properties: "y" duration: 250 easing.type: Easing.InOutQuad } } } } } 其中 import QtQuick 2.0 import QtQuick.Window 2.2 import QtQuick.VirtualKeyboard 2.1 必需要有,然后InputPanel也必需要有,不然虚拟键盘不会弹出来 这只是其中一种方式,应该还有其它方法 main.cpp如下 #include "mainwindow.h" #include #include #ifdef QT_QML #include //#include //#include //#include #endif int main(int argc, char *argv[]) { #ifdef QT_QML qputenv("QT_IM_MODULE", QByteArray("qtvirtualkeyboard")); QApplication a(argc, argv); QQmlApplicationEngine eng; eng.load(QUrl(QStringLiteral("qrc:/virkey.qml"))); if(eng.rootObjects().isEmpty()) { qDebug()<<"+++eng.rootObjects().isEmpty(+++"; return -1; } #else qputenv("QT_IM_MODULE", QByteArray("Qt5input")); QApplication a(argc, argv); MainWindow w; w.show(); #endif qDebug()<<"+++qt5hello+++"; return a.exec(); } 效果如下 软键盘使用 生成库文件 由于qt5以上版本接口变换,qt4以前的软键盘无法使用,参考上面文章编译生成so文件 libQt5Inputplugin.so需要依赖googlepinyin.a文件,首先需要编译生成googlepinyin.a 然后放到工程Qt5Input目录下的pinyin目录下,参与静态编译即可 将编译生成的libQt5Inputplugin.so放到QT安装目录下的plugins/platforminputcontexts目录下 或者放到与应用程序同级目录的platforminputcontexts目录下 将Qt5Input目录中的dict和images目录放到目标板同一个目录中 然后声明环境变量QT5_INPUT_DIR 例如将dict和images目录放在/QTDIR/qt5inputdir的目录下,然后声明如下 export QT5_INPUT_DIR=/QTDIR/qt5inputdir 或者在main.cpp中进行设置 工程文件修改 将.pro文件中DEFINES += QT_QML注释掉,然后使用默认ui布局增加输入框 main.cpp不用修改 效果如下 原作者:红尘六欲 |
飞凌嵌入式ElfBoard ELF 1板卡-内核空间与用户空间的数据拷贝之数据拷贝介绍
420 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-字符驱动测试示例
727 浏览 0 评论
虚拟机下ubuntu重启后,进不来图形界面,只能在命令终端,不是因为内部不够的问题,因为已经删过内存了
2134 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-字符驱动之字符驱动框架描述
1760 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB转网络
484 浏览 0 评论
GMT+8, 2025-3-20 04:37 , Processed in 0.576775 second(s), Total 70, Slave 54 queries .
