75W + 75W output power at THD = 10% with RL = 4 Ω and VCC = 25.5V• 55W + 55W output power at THD = 10% with RL = 6 Ω and VCC = 25.5V• 1 x 110W output power mono parallel BTL at THD = 10% with RL = 3Ω andVCC = 26V• Wide-range single-supply operation (7 - 26V) • High efficiency (η = 85%) • Four selectable, fixed gain settings of nominally 20.8 dB, 26.8 dB, 30 dBand32.8 dB• Differential inputs minimize common-mode noise• Standby and mute features• Smart protection• Thermal overload protection• Output power limited by PLIMIT function• Small offset less than 20 mV
可以替换TPA3116.
1547 浏览 0 评论
3105 浏览 0 评论
10647 浏览 0 评论
8807 浏览 0 评论
8832 浏览 0 评论
GMT+8, 2025-4-13 10:06 , Processed in 0.402087 second(s), Total 41, Slave 33 queries .
