在android系统中有标准定义的走下面这个流程:比如音量加减,电源
先找到对应的navigation_bar.xml,添加如下: android:layout_height="match_parent" android:layout_weight="0" android:src="//www.obk20.com/bbs/@drawable/ic_sy***ar_poweroff" android:scaleType="centerInside" systemui:keyCode="142" /> 这里的systemui:keyCode="142"对应的你要上报的按键键值,我这里用的空闲的F12 base/policy/src/com/android/internal/policy/impl/PhoneWindowManager.java 在interceptKeyBeforeQueueing方法中添加监听: case KeyEvent.KEYCODE_F12: { if (down) { interceptPowerKeyDown(event, true); } break; } 下面走一下非android系统定义流程: 添加控件 android:layout_height="match_parent" android:layout_weight="0" android:src="//www.obk20.com/bbs/@drawable/ic_sy***ar_poweroff" android:scaleType="centerInside" /> frameworksbasepackagesSystemUIsrccomandroidsystemuistatu***arphonenavigationBarView.java public View getPowerButton(){ return mCurrentView.findViewById(R.id.poweroff); } frameworksbasepackagesSystemUIsrccomandroidsystemuistatu***arphonePhoneStatusBar.java onConfigurationChanged-----> repositionNavigationBar----> mNavigationBarView.getPowerButton().setOnClickListener(mPowerOnClickListener); View.OnClickListener mPowerOnClickListener = new View.OnClickListener() { @Override public void onClick(View view) { Intent i = new Intent(); i.setAction("com.core.systemui.poweroff"); //广播名称 mContext.sendBroadcast(i); } }; 通过点击发送广播,接收到广播进行操作 frameworks/base/policy/src/com/android/internal/policy/impl/PhoneWindowManager.java //接受广播处注册广播 filter = new IntentFilter(); filter.addAction(Intent.ACTION_DREAMING_STARTED); filter.addAction(Intent.ACTION_DREAMING_STOPPED); filter.addAction("com.core.systemui.poweroff"); //注册广播 context.registerReceiver(mDreamReceiver, filter); //如下位置添加监听 BroadcastReceiver mDreamReceiver = new BroadcastReceiver() { @Override public void onReceive(Context context, Intent intent) { if (Intent.ACTION_DREAMING_STARTED.equals(intent.getAction())) { if (mKeyguardDelegate != null) { mKeyguardDelegate.onDreamingStarted(); } } else if (Intent.ACTION_DREAMING_STOPPED.equals(intent.getAction())) { if (mKeyguardDelegate != null) { mKeyguardDelegate.onDreamingStopped(); } //添加如下代码 } else if ("com.core.systemui.poweroff".equals(intent.getAction())) { interceptPowerKeyDown(event, true); } } }; 原作者:会飞的牛1 |
896 浏览 0 评论
614 浏览 0 评论
Onenet云网关方案应用--基于米尔瑞芯微RK3576开发板
1187 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】Redis最新8.0.2版本源码安装及性能测试
1865 浏览 0 评论
2085 浏览 0 评论
GMT+8, 2025-7-13 14:55 , Processed in 0.638596 second(s), Total 72, Slave 55 queries .
