MK9218
100V Synchronous Buck DC/DC Controller 应用: · POL modules · High-Power Density DC – DC · Datacom, Telecom · Non-isolated PoE and IP cameras 详情介绍: The MK9218 operates over a wide input voltage range from 6V to 100V. With appropriate high-side and low-side MOSFET and Inductance, the MK9218 delivers up to 30A output current. The MK9218 adopts a voltage mode control architecture to achieve excellent accurate voltage output. The switching frequency is adjustable up to 1 MHz, which also can be synchronized to an external clock source to eliminate beat frequencies in noise-sensitive applications. MK9218 support Forced-PWM (FPWM) and Diode Emulation Mode; FPWM operation eliminates switching frequency variation to minimize EMI, while user selectable diode emulation lowers current consumption at light-load condition. MK9218 is offered with wide duty cycle from 1% to 99% under appropriate switching frequency, so input and output voltage can easy to be choose. The MK9218 provides a power good (PG) flag pin to indicate output voltage. 典型应用框图及效率测试结果 |
2268 浏览 0 评论
5817 浏览 0 评论
3403 浏览 2 评论
6407 浏览 2 评论
4208 浏览 0 评论
GMT+8, 2024-12-27 07:14 , Processed in 0.454730 second(s), Total 66, Slave 49 queries .
