之前是好的,不知道问题出现在哪里?请高手指导。按道理这个文件是标识文件,系统会自动生成。.stamp_target_installed 报错信息如下: >>> rkwifibt 1.0.0 Installing to target mkdir -p /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/lib/modules mkdir -p /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/system/etc/firmware /usr/bin/install -D -m 0644 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/firmware/broadcom/AW-CM256/wifi/* /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/system/etc/firmware /usr/bin/install -D -m 0644 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/firmware/broadcom/AW-CM256/bt/* /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/system/etc/firmware /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/brcm_patchram_plus1 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/brcm_patchram_plus1 /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/dhd_priv /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/dhd_priv sed -i 's/MODULE_PATH//usr/lib/modules/bcmdhd.ko/g' /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/S66load_wifi_modules /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/S66load_wifi_modules /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/etc/init.d sed -i 's/BTFIRMWARE_PATH//system/etc/firmware/BCM4345C0.hcd/g' /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/bt_load_broadcom_firmware sed -i 's/BT_TTY_DEV//dev/ttyS4/g' /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/bt_load_broadcom_firmware /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/bt_load_broadcom_firmware /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_load_broadcom_firmware /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/bin/arm64/* /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/ /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/wpa_supplicant.conf /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/etc /usr/bin/install -D -m 0755 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/wifi_start.sh /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin rm -rf /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_PCBa_test rm -rf /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_init.sh cp -r /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_load_broadcom_firmware /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_pcba_test cp -r /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_load_broadcom_firmware /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/target/usr/bin/bt_init.sh /bin/sed -i -e "/load wifi modules/a\ insmod /system/lib/modules/cywdhd.ko" /bin/sed: no input files package/pkg-generic.mk:328: recipe for target '/home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/.stamp_target_installed' failed make[1]: *** [/home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/build/rkwifibt-1.0.0/.stamp_target_installed] Error 4 /home/kang/RK/RK3308/buildroot/output/rockchip_rk3308_release/Makefile:16: recipe for target '_all' failed make: *** [_all] Error 2 Command exited with non-zero status 1 you take 2:48:55 to build builroot ====Build buildroot failed!==== |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 20:35 , Processed in 0.619154 second(s), Total 69, Slave 53 queries .
