感谢指导,我试一下先
我试了编不过
CC lib/timerqueue.o CC lib/vsprintf.o LD lib/built-in.o AR lib/lib.a Message from syslogd@localhost at Apr 30 12:31:57 ... kernel:NMI watchdog: BUG: soft lockup - CPU#0 stuck for 21s! [aarch64-linux-g:46512] Message from syslogd@localhost at Apr 30 12:32:20 ... kernel:NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [kswapd0:30] Message from syslogd@localhost at Apr 30 12:33:02 ... kernel:NMI watchdog: BUG: soft lockup - CPU#0 stuck for 35s! [aarch64-linux-g:46512] |
按您提供的方法,编译了内核,还是没办法运行docker
[root@toybrick ~]# [root@toybrick ~]# docker run node /usr/bin/docker-current: Error response from daemon: failed to create endpoint mystifying_babbage on network bridge: failed to add the host (veth4d2a279) <=> sandbox (vethde38836) pair interfaces: operation not supported. ERRO[0164] error getting events from daemon: net/http: request canceled [root@toybrick ~]# |
我在Ubuntu上交叉编译一直不成功,请问编译成功的镜像可以分享一下吗,万分感谢
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
626 浏览 0 评论
887 浏览 1 评论
784 浏览 1 评论
1997 浏览 1 评论
3242 浏览 1 评论
GMT+8, 2024-12-24 01:36 , Processed in 0.449037 second(s), Total 46, Slave 41 queries .
