1.说明 LT86104SXE是Lontium的第四代4端口HDMI / DVI分配器,可以将一个HDMI / DVI信号转发到4个HDMI / DVI信号集,最多支持4个不同的HDMI / DVI接收/显示端子。它基于ClearedEdge™威廉希尔官方网站
,支持每通道高达3.4Gbps的数据速率,符合HDMI 1.4 / DVI 1.0规范。 2.功能 •兼容HDMI 1.4 / 2.0和DVI 1.0规范 •支持高达3.4Gbps数据速率的3D视频格式和4Kx2K扩展分辨率格式,以及60Hz YCbCr 4:2:0格式的4Kx2K •自适应均衡和去加重以补偿长时间电缆损耗 •ODT和校准 •符合HDCP 1.4规范的集成HDCP转发器引擎 •完全由硬件控制或可选的软件控制的HDCP操作 •预编程的HDCP密钥集或外部EEPROM存储的密钥集 •集成CEC控制器 •集成EDID影子RAM和嵌入式EDID •耐5V的DDC接口 •1个HDMI / DVI输入端口,最多4个HDMI / DVI输出端口 •无限级联,用于更多输出端口或信号转发 •128针LQFP封装 3.应用 •多显示器/电视支持 •HDMI / DVI信号分离/重复 TheLT86104SXEis Lontium's fourth-generation 4-port HDMI/DVI splitter that can forward one HDMI/DVI signal to four HDMI/DVI signal sets, supporting up to four different HDMI/DVI receiving/display terminals. It is based on ClearedEdge technology and supports data rates up to 3.4Gbps per channel, conforming to the HDMI 1.4 / DVI 1.0 specificationFunction of 2. Compatible with HDMI 1.4/2.0 and DVI 1.0 specifications Supports 3D video formats up to 3.4Gbps data rates and 4Kx2K extended resolution formats, as well as 4Kx2K in 60Hz YCbCr 4:2:0 format Adaptive equalization and de-weighting to compensate for long time cable losses the ODT and calibration Integrated HDCP transponder engine that complies with HDCP 1.4 specification Full hardware controlled or optional software controlled HDCP operation Pre-programmed HDCP key set or external EEPROM stored key set Integrated CEC controller Integrated EDID shadow RAM and embedded EDID 5V DDC interface 1 HDMI/DVI input port, up to 4 HDMI/DVI output ports Unlimited cascade for more output ports or signal forwarding
1 个讨论
你正在撰写讨论
3628 浏览 2 评论
RK3588 HDMI in 接入设备如何获取HDMI in 传入的音频?
4035 浏览 1 评论
25750 浏览 1 评论
【KV260威廉希尔官方网站 分享】宿主机构建Gstreamer
1407 浏览 0 评论
硬创大赛项目专访 | 田奕鑫:专注细分领域创新,我们和行业巨头“化敌为友”
94844 浏览 1 评论
GMT+8, 2025-3-26 20:31 , Processed in 0.719785 second(s), Total 40, Slave 33 queries .
