CPU:RK3288
系统:Android 5.1 主板有两个USB接口,一个接USB摄像头,一个接身份证模块。 插入摄像头可以正常打开,再插入身份证模块时,摄像头就会卡主,而且身份证模块无法识别,内核log如下: [ 208.492045] u*** 3-1.3: new full-speed USB device number 7 using u***20_host [ 208.571251] u*** 3-1.3: device descriptor read/64, error -32 [ 208.758662] u*** 3-1.3: device descriptor read/64, error -32 [ 208.945433] u*** 3-1.3: new full-speed USB device number 8 using u***20_host [ 209.024159] u*** 3-1.3: device descriptor read/64, error -32 [ 209.211003] u*** 3-1.3: device descriptor read/64, error -32 [ 209.398208] u*** 3-1.3: new full-speed USB device number 9 using u***20_host [ 209.810731] u*** 3-1.3: device not accepting address 9, error -32 [ 209.890155] u*** 3-1.3: new full-speed USB device number 10 using u***20_host [ 210.302863] u*** 3-1.3: device not accepting address 10, error -32 [ 210.303805] hub 3-1:1.0: unable to enumerate USB device on port 3 有时可以识别身份证模块,内核log如下: [ 743.983805] u*** 3-1.4: new full-speed USB device number 10 using u***20_host [ 744.062096] u*** 3-1.4: device descriptor read/64, error -32 [ 744.270232] u*** 3-1.4: New USB device found, idVendor=0400, idProduct=c35a [ 744.270433] u*** 3-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0 出现这种现象的原因是2组USB使用同一路供电,当身份证模块插入时,瞬间拉低了USB电源,导致USB供电不足。 两种解决办法: 1、两组USB单独供电; 2、在USB电源上接一个较大的电容,防止电压瞬间被拉低。 |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
849 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
999 浏览 0 评论
488 浏览 0 评论
457 浏览 0 评论
776 浏览 0 评论
GMT+8, 2025-2-23 15:24 , Processed in 0.586019 second(s), Total 74, Slave 55 queries .
