rk3288提供了fiq debugger功能, 因此rk将debug uart和普通uart区分开来,
debug uart的初始化集成到了fiq debugger代码中完成,不过uart的初始化 方法还是遵循linux的uart初始化标准,包括tty driver分配,注册, ops的设置等. 代码中和uart debugger相关的用宏CONFIG_FIQ_DEBUGGER_CONSOLE包起来了, 只看这部分即可. 初始化部分: fiq_debugger_init -> fiq_debugger.c fiq_debugger_tty_init -> alloc_tty_driver //分配一个tty driver,后面并填充 tty_set_operations //设置tty对应的struct tty_operations, 为fiq_tty_driver_ops,最终会操作到rk_fiq_debugger.c中的接口函数. tty_register_driver //注册tty driver到serial core中,让系统知道此tty driver的存在. platform_driver_register(&fiq_debugger_driver) -> //对应的platform device在rk_fiq_debugger.c而不是dts中. fiq_debugger_probe -> request_irq //irq处理函数fiq_debugger_uart_irq() register_console //注册后当前console,printk()输出log的时候就会调用它最终输出到调试串口. 注册对应的console是fiq_debugger_console //static struct console fiq_debugger_console = { //.name = "ttyFIQ", //最后的字符设备就是/dev/ttyFIQx //.write = fiq_debugger_console_write, //printk()最终会调用它. //}; fiq_debugger_tty_init_one -> //初始化并注册uart port, 上一篇分析串口驱动有说过,,每个串口用port表示 tty_port_init tty_port_register_device 可以看到和标准的串口驱动注册类似. printk()输出log: printk -> vprintk_emit -> console_unlock console_cont_flush -> printk.c call_console_drivers -> con->write -> //调用对用cosole的write()函数 fiq_debugger_console_write fiq_debugger.c state->pdata->console_write //如果有就调用console thread去输出. fiq_debugger_putc -> state->pdata->uart_putc -> 此函数在rk_fiq_debugger.c的rk_serial_debug_init()中注册 debug_putc -> rk_fiq_debugger.c rk_fiq_write 用户空间write: SyS_write -> vfs_write -> tty_write -> n_tty_write -> process_output_block -> tty->ops->write -> //前面有注册了tty driver对应的ops为fiq_tty_driver_ops fiq_tty_write -> fiq_debugger_putc -> state->pdata->uart_putc -> 此函数在rk_fiq_debugger.c的rk_serial_debug_init()中注册 debug_putc -> rk_fiq_debugger.c rk_fiq_write 两种方式最终调用输出接口一样. |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1763 浏览 0 评论
2180 浏览 1 评论
1850 浏览 1 评论
3188 浏览 1 评论
4058 浏览 1 评论
GMT+8, 2025-1-12 05:47 , Processed in 0.327310 second(s), Total 41, Slave 34 queries .
