1, linux下 unpack 解包
报错 root@Ubuntu:/opt/rk-linux/mkimg# ./unpack.sh start to unpack update.img... ********RKImageMaker ver 1.61******** Unpacking image, please wait... Error:update.img is not exist! Press any key to quit: 解包的命令有问题,在linux下不能正常解包 2, 继续打包. 测试在安卓下面运行是可以的: liupingwei@xdtUbuntu:~/RK3288/rk3288Android5.1$ ./FFTools/mkupdate/mkupdate.sh PRODUCT_FIREFLY_NAME=Public TARGET_PRODUCT=rk3288_box Android Firmware Package Tool v1.62 ------ PACKAGE ------ Add file: ./package-file Add file: ./Image/MiniLoaderAll.bin Add file: ./Image/parameter.txt Add file: ./Image/misc.img Add file: ./Image/resource.img Add file: ./Image/kernel.img Add file: ./Image/boot.img Add file: ./Image/recovery.img Add file: ./Image/system.img Add CRC... Make firmware OK! ------ OK ------ ********RKImageMaker ver 1.63******** Generating new image, please wait... Writing head info... Writing boot file... Writing firmware... Generating MD5 data... MD5 data generated successfully! New image generated successfully! Making updateimg: rockdev/Image-rk3288_box/Firefly-RK3288_Android5.1.1_Public_181023.img 应该是缺少环境变量配置,所以才会 导致直接执行不通 3, 找到原因, 执行脚本的时候有个字符不匹配: ./afptool -pack ./ Image/update.img || pause ./rkImageMaker -RK32 RK3288Loader_uboot_V2.15.01.bin Image/update.img update.img -os_type:androidos || pause # Ubuntt# ./rkImageMaker -RK32 rk3288_bootloader_v1.00.06.bin Image/update.img update.img -os_type:androidos || pause # 后可生成 ./afptool -pack ./ Image/update.img || pause liupingwei@xdtUbuntu:~/RK3288/rk3288Android5.1/RKTools/linux/Linux_Upgrade_Tool_v1.2/rockdev$ ./rkImageMaker -RK32 rk3288_bootloader_v1.00.06.bin Image/update.img update.img -os_type:androidos || pause ********RKImageMaker ver 1.61******** Generating new image, please wait... Writing head info... Writing boot file... Writing firmware... Generating MD5 data... MD5 data generated successfully! New image generated successfully! 改成新的脚本执行: root@Ubuntu:/opt/rk-linux/mkimg# ./umkupdate_ubuntu.sh start to make update.img... Android Firmware Package Tool v1.0 ------ PACKAGE ------ Add file: ./package-file Add file: ./rk3288_bootloader_v1.00.06.bin Add file: ./parameter Add file: ./linux-kernel.img Add file: ./linux-resource.img Add file: ./ubuntu1604armhf-rootfs.img Add file: ./update-script Add file: ./recover-script Add CRC... Make firmware OK! ------ OK ------ ********RKImageMaker ver 1.61******** Generating new image, please wait... Writing head info... Writing boot file... Writing firmware... Generating MD5 data... MD5 data generated successfully! New image generated successfully! Making update.img OK. Press any key to quit: 4, 文件系统制作的在显卡部分应该有问题,导致启动卡死在 显卡驱动部分 5, 继续制作文件系统 替换\192.168.0.102optrk-linuxmkimg 目录下的 ubuntu1604armhf-rootfs.img cd .. ./ch-mount.sh -m linux-rootfs 进入挂载模式 3、卸载软件 1)sudo apt-get remove XXXX #卸载软件(删除软件包) 2)sudo apt-get autoremove XXXX #自动卸载软件但保留其配置文件 3)sudo apt-get autoremove --purge XXXX #自动卸载软件其删除其配置文件 --------------------- apt-get autoremove --purge ubuntu-session xubuntu-desktop 重新安装: root@Ubuntu:/# apt-get install ubuntu-session xubuntu-desktop Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: xubuntu-desktop : Depends: gtk2-engines-pixbuf but it is not going to be installed Depends: xubuntu-artwork but it is not going to be installed Depends: xubuntu-core but it is not going to be installed Depends: xubuntu-default-settings but it is not going to be installed Recommends: brltty-x11 but it is not going to be installed E: Unable to correct problems, you have held broken packages. 红色部分是依赖库,需要安装: apt-get install gtk2-engines-pixbuf apt-get install xubuntu-artwork apt-get install xubuntu-core apt-get install xubuntu-default-settings apt-get install brltty-x11
root@Ubuntu:/# apt-cache policy libgtk2.0-0 libgtk2.0-0: Installed: 2.24.30-1ubuntu1.16.04.2 Candidate: 2.24.30-1ubuntu1.16.04.2 Version table: *** 2.24.30-1ubuntu1.16.04.2 500 500 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main armhf Packages 100 /var/lib/dpkg/status 2.24.30-1ubuntu1 500 500 http://ports.ubuntu.com/ubuntu-ports xenial/main armhf Packages root@Ubuntu:/# 如何指定安装2.0版本呢? apt-get autoremove --purge libgtk2.0-dev apt-cache policy libgtk2.0-dev apt-get install libgtk2.0-dev 参考: http://dev.t-firefly.com/thread-12732-1-19.html 原因: 需要clean 及重新 update NOTICE: apt-get upgrade apt-get autoclean apt-get update 后: apt-get install ubuntu-session xubuntu-desktop 正常 |
355 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】自行转换大模型失败,搞一个语音小智玩玩吧.
219 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】使用rkllm运行DeepSeek的服务模式体验
862 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】DeepSeek 部署及测试
2387 浏览 1 评论
【幸狐Omni3576边缘计算套件试用体验】RKNN 推理测试与图像识别
1920 浏览 3 评论
GMT+8, 2025-4-1 23:17 , Processed in 0.526362 second(s), Total 43, Slave 36 queries .
