有两处温度设定会对GPU有影响:
1. rk3288.dtsi clk_gpu_dvfs_table: clk_gpu { operating-points = < /* KHz uV */ 200000 1200000 300000 1200000 400000 1200000 >; channel = <1>; tsadc-ch = <2>; temp-limit-enable = <0>; target-temp = <90>; min_temp_limit = <200>; normal-temp-limit = < /*delta-temp delta-freq*/ 3 50000 6 150000 15 250000 >; regu-mode-table = < /*freq mode*/ 200000 4 0 3 >; regu-mode-en = <0>; status = "okay"; }; 当温度超过target-temp后,会按照normal-temp-limit此table中的delta_temp来降低当前的frequency为cur_freq - delta_freq, 最低值不能小于min_temp_limit. 此值用于和当前要设置的target_freq比较,如果target_freq比cur_freq - delta_freq大,那么就设置成cur_freq - delta_freq. 由于temp-limit-enable的值是0,所以此功能默认是关闭的,根据情况决定是否使能. 2. mali_kbase_dvfs.c: static void mali_dvfs_event_proc(struct work_struct *w) { int ret = 0; struct rk_dvfs_t *dvfs = work_to_dvfs(w); int temp = rockchip_tsadc_get_temp(1, 0); if (is_overheated(dvfs)) { if (could_jump_down(dvfs)) { I("to jump down for overheated, temp:%d.", dvfs->temp); ret = jump_down_actually(dvfs); if (ret) E("fail to jump down, ret:%d.", ret); } else { W("overheated! temp:%d, but can't jump down anymore.", dvfs->temp); } dvfs->temp = 0; goto EXIT; } } 通过rockchip_tsadc_get_temp()读取,如果温度过高(is_overheated()),这里的阀值设置的是110°, #define TEMP_UPPER_LIMIT (110) 那么就通过jump_down_actually()降低频率. |
436 浏览 0 评论
1477 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1077 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1701 浏览 1 评论
816 浏览 0 评论
GMT+8, 2025-3-6 02:43 , Processed in 0.863617 second(s), Total 72, Slave 54 queries .
