DTSI解析:
1. MIPI初始化 disp_mipi_init: mipi_dsi_init{ compatible = "rockchip,mipi_dsi_init"; //屏幕是否需要初始化 rockchip,screen_init = <1>; //有几条Lane, lcd drvier需要配置移植. rockchip,dsi_lane = <4>; //单位是MHz,范围在90~1500MHz, 实际会有点偏差. rockchip,dsi_hs_clk = <600>; //单MIPI还是双MIPI. rockchip,mipi_dsi_num = <1>; }; 2. 上电时序 GPIO根据你在连到屏幕的pin作修改. disp_mipi_power_ctr: mipi_power_ctr { compatible = "rockchip,mipi_power_ctr"; mipi_lcd_rst:mipi_lcd_rst{ compatible = "rockchip,lcd_rst"; //reset pin,用的是gpio7的A4 pin, 高电平有效. rockchip,gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_HIGH>; //延时多久,根据lcd spec来确定具体值. rockchip,delay = <10>; }; mipi_lcd_en:mipi_lcd_en { compatible = "rockchip,lcd_en"; //enable pin rockchip,gpios = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>; rockchip,delay = <10>; }; }; 注意,这里RK在使用GPIO_ACTIVE_HIGH是反了,比如SPEC中写着是低电平有效,那么这里要配置为GPIO_ACTIVE_HIGH,而不是GPIO_ACTIVE_LOW. 这两个PIN在lcdc节点中有重复配置,只要使用其中一组就可以. /*lcdc0 as PRMRY(LCD),lcdc1 as EXTEND(HDMI)*/ &lcdc0 { status = "okay"; rockchip,mirror = rockchip,cabc_mode = <0>; power_ctr: power_ctr { rockchip,debug = <0>; /*lcd_en:lcd_en { rockchip,power_type = gpios = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>; rockchip,delay = <10>; }; lcd_cs:lcd_cs { rockchip,power_type = gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_LOW>; rockchip,delay = <10>; };*/ }; }; 3. 初始化命令 初始化命令问屏供应商获取. disp_mipi_init_cmds: screen-on-cmds { compatible = "rockchip,screen-on-cmds"; //是否打开cmd调试 rockchip,cmd_debug = <1>; //on-cmdsxxx可以随便取,只要不重复就可以,code会按照放置而不是数字顺序读取. rockchip,on-cmds1 { compatible = "rockchip,on-cmds"; //命令在low power 还是 high speed (HSDT)发送,一般都是LPDT. rockchip,cmd_type = //用的平台哪个通道dsi,单MIPI是0, 双MIPI是2. rockchip,dsi_id = <0>; //依次是type|cmd|data, 只有一个参数用0x15. rockchip,cmd = <0x15 0xcd 0xaa>; rockchip,cmd_delay = <0>; }; //...... rockchip,on-cmds17 { compatible = "rockchip,on-cmds"; rockchip,cmd_type = rockchip,dsi_id = <0>; //依次是type|cmd|data0|data1|datax..., 长包用0x39 rockchip,cmd = <0x39 0x57 0x00 0x00 0x00 0x00>; rockchip,cmd_delay = <0>; }; //....... //下面两条命令厂家有时候不会提供,需要自己补上. rockchip,on-cmds40 { compatible = "rockchip,on-cmds"; rockchip,cmd_type = rockchip,dsi_id = <0>; //dcs_exit_sleep_mode在code中有定义,可以直接使用,包括下面的dcs_set_display_on. rockchip,cmd = <0x05 dcs_exit_sleep_mode>; rockchip,cmd_delay = <120>; }; rockchip,on-cmds41 { compatible = "rockchip,on-cmds"; rockchip,cmd_type = rockchip,dsi_id = <0>; //只有命令没有参数用0x05. rockchip,cmd = <0x05 dcs_set_display_on>; //这个延时很重要. rockchip,cmd_delay = <120>; }; }; 4. 屏幕Timing 下面几个参数需要参考屏spec来确定. disp_timings: display-timings { native-mode = <&timing0>; compatible = "rockchip,display-timings"; timing0: timing0 { //屏幕类型,双MIPI是SCREEN_DUAL_MIPI. screen-type = //无效参数 lvds-format = //屏幕pixel format out-face = //此值影响fps,刚开始fps可以低一些,比如fps,后面再慢慢加大. clock-frequency = <58200000>; //水平有效像素 hactive = <480>; //垂直有效像素 vactive = <1280>; //hbp hback-porch = <160>; //hfp hfront-porch = <160>; //vbp vback-porch = <10>; //vfp vfront-porch = <12>; //h-sync hsync-len = <24>; //v-sync vsync-len = <2>; //下面几个参数基本上不需要变化,除非屏幕显示有异常. hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <0>; swap-rb = <0>; swap-rg = <0>; swap-gb = <0>; }; }; 调试过程: 1. Log查看驱动是否已经正常跑起来,文件有一些调试宏可以打开,以获取更多有用信息. 2. 确认屏的供电电压以及复位电压正常(有遇到过板子的一个5V电源窜到复位引脚),上电时序要符合spec要求,这时屏幕可以不接,以免烧坏. 3. 如果屏幕需要初始化,确认命令是否发送成功.有如下几种方法确认: a) 用示波器抓取Lan0N和Lane0P,难度较大,不到最后一步不用. b) 把发出去的命令读回来看是否一致,前提是读取接口要正常.(我遇到的读接口就没成功,不知是不是接口问题,没有深究) c) 和厂商确认是否有类型工厂测试命令,配置完后屏可以自己显示7彩色种类的画面. 4. 如果还不亮,需要测量下Lane上面的电压,LPDT在1.2V左右,HSDT在200mV左右.如果还是正常,就需要分析MIPI协议了,这一步一个是需要设备,一个是分析时间会很长. 5.还有个情况就是是否使用了转接板,因为是高速信号,所以fpc线要求要高. 我就被这问题折磨了整整一周,后来换了插口和短的线就有显示了. |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 22:52 , Processed in 0.464488 second(s), Total 42, Slave 34 queries .
