相关文件:
kernel/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c kernel/drivers/gpu/drm/drm_edid.c 修改kernel/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c文件如下 修改 def_modes 的值,对应的是 vic 值,如果 4 对应的是 edid_cea_modes 中的: /* 4 - 1280x720@60Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 1390, 1430, 1650, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, diff --git a/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c b/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c old mode 100644 new mode 100755 index d57d999c50a5..9a2e086f14e8 --- a/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c --- a/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c +++ b/drivers/gpu/drm/bridge/synopsys/dw-hdmi.c @@ -2497,7 +2497,10 @@ static int dw_hdmi_connector_get_modes(struct drm_connector *connector) connector); struct edid *edid; struct drm_display_mode *mode; - const u8 def_modes[6] = {4, 16, 31, 19, 17, 2}; + // 20200406 modified by dongshiyi for changing the default hdmi resolution to 3840x2160p@30Hz start +// const u8 def_modes[6] = {4, 16, 31, 19, 17, 2}; + const u8 def_modes[6] = {105, 100, 31, 19, 17, 2};//把def_mode数组的第一个值对应的是默认显示hdmi的分辨率对应的 vic(dw-hdmi.c文件中).我这里修改为105代表选用3840x2160p@30Hz为默认hdmi输出分辨率 + // 20200406 modified by dongshiyi for changing the default hdmi resolution to 3840x2160p@30Hz end struct drm_display_info *info = &connector->display_info; struct hdr_static_metadata *metedata = &connector->display_info.hdmi.hdr_panel_metadata; @@ -2506,7 +2509,11 @@ static int dw_hdmi_connector_get_modes(struct drm_connector *connector) if (!hdmi->ddc) return 0; - edid = drm_get_edid(connector, hdmi->ddc); + +// 20200406 modified by dongshiyi for changing the default hdmi resolution to 3840x2160p@30Hz start +// edid = drm_get_edid(connector, hdmi->ddc); + edid = NULL;//edid = NULL;强制把edid赋为NULL,不管有没有读到edid都强制按def_modes来显示 +// 20200406 modified by dongshiyi for changing the default hdmi resolution to 3840x2160p@30Hz end if (edid) { dev_dbg(hdmi->dev, "got edid: width[%d] x height[%d]n", edid->width_cm, edid->height_cm); 下面来看看edid_cea_modes数组定义的分辨率,可在最后定义特殊的分辨率(drm_edid.c文件中) /* * Probably taken from CEA-861 spec. * This table is converted from xorg's hw/xfree86/modes/xf86EdidModes.c. * * Index using the VIC. */ static const struct drm_display_mode edid_cea_modes[] = { /* 0 - dummy, VICs start at 1 */ { }, /* 1 - 640x480@60Hz */ { DRM_MODE("640x480", DRM_MODE_TYPE_DRIVER, 25175, 640, 656, 752, 800, 0, 480, 490, 492, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 2 - 720x480@60Hz */ { DRM_MODE("720x480", DRM_MODE_TYPE_DRIVER, 27000, 720, 736, 798, 858, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 3 - 720x480@60Hz */ { DRM_MODE("720x480", DRM_MODE_TYPE_DRIVER, 27000, 720, 736, 798, 858, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 4 - 1280x720@60Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 1390, 1430, 1650, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 5 - 1920x1080i@60Hz */ { DRM_MODE("1920x1080i", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1094, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 6 - 720(1440)x480i@60Hz */ { DRM_MODE("720x480i", DRM_MODE_TYPE_DRIVER, 13500, 720, 739, 801, 858, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 7 - 720(1440)x480i@60Hz */ { DRM_MODE("720x480i", DRM_MODE_TYPE_DRIVER, 13500, 720, 739, 801, 858, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 8 - 720(1440)x240@60Hz */ { DRM_MODE("720x240", DRM_MODE_TYPE_DRIVER, 13500, 720, 739, 801, 858, 0, 240, 244, 247, 262, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_DBLCLK), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 9 - 720(1440)x240@60Hz */ { DRM_MODE("720x240", DRM_MODE_TYPE_DRIVER, 13500, 720, 739, 801, 858, 0, 240, 244, 247, 262, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_DBLCLK), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 10 - 2880x480i@60Hz */ { DRM_MODE("2880x480i", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2956, 3204, 3432, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 11 - 2880x480i@60Hz */ { DRM_MODE("2880x480i", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2956, 3204, 3432, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 12 - 2880x240@60Hz */ { DRM_MODE("2880x240", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2956, 3204, 3432, 0, 240, 244, 247, 262, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 13 - 2880x240@60Hz */ { DRM_MODE("2880x240", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2956, 3204, 3432, 0, 240, 244, 247, 262, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 14 - 1440x480@60Hz */ { DRM_MODE("1440x480", DRM_MODE_TYPE_DRIVER, 54000, 1440, 1472, 1596, 1716, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 15 - 1440x480@60Hz */ { DRM_MODE("1440x480", DRM_MODE_TYPE_DRIVER, 54000, 1440, 1472, 1596, 1716, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 16 - 1920x1080@60Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 148500, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 17 - 720x576@50Hz */ { DRM_MODE("720x576", DRM_MODE_TYPE_DRIVER, 27000, 720, 732, 796, 864, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 18 - 720x576@50Hz */ { DRM_MODE("720x576", DRM_MODE_TYPE_DRIVER, 27000, 720, 732, 796, 864, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 19 - 1280x720@50Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 1720, 1760, 1980, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 20 - 1920x1080i@50Hz */ { DRM_MODE("1920x1080i", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1094, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 21 - 720(1440)x576i@50Hz */ { DRM_MODE("720x576i", DRM_MODE_TYPE_DRIVER, 13500, 720, 732, 795, 864, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 22 - 720(1440)x576i@50Hz */ { DRM_MODE("720x576i", DRM_MODE_TYPE_DRIVER, 13500, 720, 732, 795, 864, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 23 - 720(1440)x288@50Hz */ { DRM_MODE("720x288", DRM_MODE_TYPE_DRIVER, 13500, 720, 732, 795, 864, 0, 288, 290, 293, 312, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_DBLCLK), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 24 - 720(1440)x288@50Hz */ { DRM_MODE("720x288", DRM_MODE_TYPE_DRIVER, 13500, 720, 732, 795, 864, 0, 288, 290, 293, 312, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_DBLCLK), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 25 - 2880x576i@50Hz */ { DRM_MODE("2880x576i", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2928, 3180, 3456, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 26 - 2880x576i@50Hz */ { DRM_MODE("2880x576i", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2928, 3180, 3456, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 27 - 2880x288@50Hz */ { DRM_MODE("2880x288", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2928, 3180, 3456, 0, 288, 290, 293, 312, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 28 - 2880x288@50Hz */ { DRM_MODE("2880x288", DRM_MODE_TYPE_DRIVER, 54000, 2880, 2928, 3180, 3456, 0, 288, 290, 293, 312, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 29 - 1440x576@50Hz */ { DRM_MODE("1440x576", DRM_MODE_TYPE_DRIVER, 54000, 1440, 1464, 1592, 1728, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 30 - 1440x576@50Hz */ { DRM_MODE("1440x576", DRM_MODE_TYPE_DRIVER, 54000, 1440, 1464, 1592, 1728, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 31 - 1920x1080@50Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 148500, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 32 - 1920x1080@24Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2558, 2602, 2750, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 33 - 1920x1080@25Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 34 - 1920x1080@30Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 35 - 2880x480@60Hz */ { DRM_MODE("2880x480", DRM_MODE_TYPE_DRIVER, 108000, 2880, 2944, 3192, 3432, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 36 - 2880x480@60Hz */ { DRM_MODE("2880x480", DRM_MODE_TYPE_DRIVER, 108000, 2880, 2944, 3192, 3432, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 37 - 2880x576@50Hz */ { DRM_MODE("2880x576", DRM_MODE_TYPE_DRIVER, 108000, 2880, 2928, 3184, 3456, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 38 - 2880x576@50Hz */ { DRM_MODE("2880x576", DRM_MODE_TYPE_DRIVER, 108000, 2880, 2928, 3184, 3456, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 39 - 1920x1080i@50Hz */ { DRM_MODE("1920x1080i", DRM_MODE_TYPE_DRIVER, 72000, 1920, 1952, 2120, 2304, 0, 1080, 1126, 1136, 1250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 40 - 1920x1080i@100Hz */ { DRM_MODE("1920x1080i", DRM_MODE_TYPE_DRIVER, 148500, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1094, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 41 - 1280x720@100Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 148500, 1280, 1720, 1760, 1980, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 42 - 720x576@100Hz */ { DRM_MODE("720x576", DRM_MODE_TYPE_DRIVER, 54000, 720, 732, 796, 864, 0, 576, 581, 586, 625, 0, |
.vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 43 - 720x576@100Hz */ { DRM_MODE("720x576", DRM_MODE_TYPE_DRIVER, 54000, 720, 732, 796, 864, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 44 - 720(1440)x576i@100Hz */ { DRM_MODE("720x576i", DRM_MODE_TYPE_DRIVER, 27000, 720, 732, 795, 864, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 45 - 720(1440)x576i@100Hz */ { DRM_MODE("720x576i", DRM_MODE_TYPE_DRIVER, 27000, 720, 732, 795, 864, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 46 - 1920x1080i@120Hz */ { DRM_MODE("1920x1080i", DRM_MODE_TYPE_DRIVER, 148500, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1094, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC | DRM_MODE_FLAG_INTERLACE), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 47 - 1280x720@120Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 148500, 1280, 1390, 1430, 1650, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 48 - 720x480@120Hz */ { DRM_MODE("720x480", DRM_MODE_TYPE_DRIVER, 54000, 720, 736, 798, 858, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 49 - 720x480@120Hz */ { DRM_MODE("720x480", DRM_MODE_TYPE_DRIVER, 54000, 720, 736, 798, 858, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 50 - 720(1440)x480i@120Hz */ { DRM_MODE("720x480i", DRM_MODE_TYPE_DRIVER, 27000, 720, 739, 801, 858, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 51 - 720(1440)x480i@120Hz */ { DRM_MODE("720x480i", DRM_MODE_TYPE_DRIVER, 27000, 720, 739, 801, 858, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 52 - 720x576@200Hz */ { DRM_MODE("720x576", DRM_MODE_TYPE_DRIVER, 108000, 720, 732, 796, 864, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 200, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 53 - 720x576@200Hz */ { DRM_MODE("720x576", DRM_MODE_TYPE_DRIVER, 108000, 720, 732, 796, 864, 0, 576, 581, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 200, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 54 - 720(1440)x576i@200Hz */ { DRM_MODE("720x576i", DRM_MODE_TYPE_DRIVER, 54000, 720, 732, 795, 864, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 200, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 55 - 720(1440)x576i@200Hz */ { DRM_MODE("720x576i", DRM_MODE_TYPE_DRIVER, 54000, 720, 732, 795, 864, 0, 576, 580, 586, 625, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 200, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 56 - 720x480@240Hz */ { DRM_MODE("720x480", DRM_MODE_TYPE_DRIVER, 108000, 720, 736, 798, 858, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 240, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 57 - 720x480@240Hz */ { DRM_MODE("720x480", DRM_MODE_TYPE_DRIVER, 108000, 720, 736, 798, 858, 0, 480, 489, 495, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC), .vrefresh = 240, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 58 - 720(1440)x480i@240 */ { DRM_MODE("720x480i", DRM_MODE_TYPE_DRIVER, 54000, 720, 739, 801, 858, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 240, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_4_3, }, /* 59 - 720(1440)x480i@240 */ { DRM_MODE("720x480i", DRM_MODE_TYPE_DRIVER, 54000, 720, 739, 801, 858, 0, 480, 488, 494, 525, 0, DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_INTERLACE | DRM_MODE_FLAG_DBLCLK), .vrefresh = 240, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 60 - 1280x720@24Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 59400, 1280, 3040, 3080, 3300, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 61 - 1280x720@25Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 3700, 3740, 3960, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 62 - 1280x720@30Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 3040, 3080, 3300, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 63 - 1920x1080@120Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 297000, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 64 - 1920x1080@100Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 297000, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 65 - 1280x720@24Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 59400, 1280, 3040, 3080, 3300, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 66 - 1280x720@25Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 3700, 3740, 3960, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 67 - 1280x720@30Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 3040, 3080, 3300, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 68 - 1280x720@50Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 1720, 1760, 1980, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 69 - 1280x720@60Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 74250, 1280, 1390, 1430, 1650, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 70 - 1280x720@100Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 148500, 1280, 1720, 1760, 1980, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 71 - 1280x720@120Hz */ { DRM_MODE("1280x720", DRM_MODE_TYPE_DRIVER, 148500, 1280, 1390, 1430, 1650, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 72 - 1920x1080@24Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2558, 2602, 2750, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 73 - 1920x1080@25Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 74 - 1920x1080@30Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 74250, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 75 - 1920x1080@50Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 148500, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 76 - 1920x1080@60Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 148500, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 77 - 1920x1080@100Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 297000, 1920, 2448, 2492, 2640, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 78 - 1920x1080@120Hz */ { DRM_MODE("1920x1080", DRM_MODE_TYPE_DRIVER, 297000, 1920, 2008, 2052, 2200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 79 - 1680x720@24Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 59400, 1680, 3040, 3080, 3300, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 80 - 1680x720@25Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 59400, 1680, 2908, 2948, 3168, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 81 - 1680x720@30Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 59400, 1680, 2380, 2420, 2640, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 82 - 1680x720@50Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 82500, 1680, 1940, 1980, 2200, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 83 - 1680x720@60Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 99000, 1680, 1940, 1980, 2200, 0, 720, 725, 730, 750, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 84 - 1680x720@100Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 165000, 1680, 1740, 1780, 2000, 0, 720, 725, 730, 825, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 85 - 1680x720@120Hz */ { DRM_MODE("1680x720", DRM_MODE_TYPE_DRIVER, 198000, 1680, 1740, 1780, 2000, 0, 720, 725, 730, 825, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 86 - 2560x1080@24Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 99000, 2560, 3558, 3602, 3750, 0, 1080, 1084, 1089, 1100, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 87 - 2560x1080@25Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 90000, 2560, 3008, 3052, 3200, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 88 - 2560x1080@30Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 118800, 2560, 3328, 3372, 3520, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 89 - 2560x1080@50Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 185625, 2560, 3108, 3152, 3300, 0, 1080, 1084, 1089, 1125, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 90 - 2560x1080@60Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 198000, 2560, 2808, 2852, 3000, 0, 1080, 1084, 1089, 1100, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 91 - 2560x1080@100Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 371250, 2560, 2778, 2822, 2970, 0, 1080, 1084, 1089, 1250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 100, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 92 - 2560x1080@120Hz */ { DRM_MODE("2560x1080", DRM_MODE_TYPE_DRIVER, 495000, 2560, 3108, 3152, 3300, 0, 1080, 1084, 1089, 1250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 120, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 93 - 3840x2160p@24Hz 16:9 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 297000, 3840, 5116, 5204, 5500, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9,}, /* 94 - 3840x2160p@25Hz 16:9 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 297000, 3840, 4896, 4984, 5280, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 95 - 3840x2160p@30Hz 16:9 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 297000, 3840, 4016, 4104, 4400, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 96 - 3840x2160p@50Hz 16:9 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 594000, 3840, 4896, 4984, 5280, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 97 - 3840x2160p@60Hz 16:9 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 594000, 3840, 4016, 4104, 4400, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_16_9, }, /* 98 - 4096x2160p@24Hz 256:135 */ { DRM_MODE("4096x2160", DRM_MODE_TYPE_DRIVER, 297000, 4096, 5116, 5204, 5500, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_256_135, }, /* 99 - 4096x2160p@25Hz 256:135 */ { DRM_MODE("4096x2160", DRM_MODE_TYPE_DRIVER, 297000, 4096, 5064, 5152, 5280, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_256_135, }, /* 100 - 4096x2160p@30Hz 256:135 */ { DRM_MODE("4096x2160", DRM_MODE_TYPE_DRIVER, 297000, 4096, 4184, 4272, 4400, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_256_135, }, /* 101 - 4096x2160p@50Hz 256:135 */ { DRM_MODE("4096x2160", DRM_MODE_TYPE_DRIVER, 594000, 4096, 5064, 5152, 5280, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_256_135, }, /* 102 - 4096x2160p@60Hz 256:135 */ { DRM_MODE("4096x2160", DRM_MODE_TYPE_DRIVER, 594000, 4096, 4184, 4272, 4400, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_256_135, }, /* 103 - 3840x2160p@24Hz 64:27 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 297000, 3840, 5116, 5204, 5500, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 24, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 104 - 3840x2160p@25Hz 64:27 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 297000, 3840, 4896, 4984, 5280, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 25, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 105 - 3840x2160p@30Hz 64:27 这个就是我上面选用的默认hdmi分辨率 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 297000, 3840, 4016, 4104, 4400, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 30, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 106 - 3840x2160p@50Hz 64:27 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 594000, 3840, 4896, 4984, 5280, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 50, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, /* 107 - 3840x2160p@60Hz 64:27 */ { DRM_MODE("3840x2160", DRM_MODE_TYPE_DRIVER, 594000, 3840, 4016, 4104, 4400, 0, 2160, 2168, 2178, 2250, 0, DRM_MODE_FLAG_PHSYNC | DRM_MODE_FLAG_PVSYNC), .vrefresh = 60, .picture_aspect_ratio = HDMI_PICTURE_ASPECT_64_27, }, }; |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
849 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
999 浏览 0 评论
488 浏览 0 评论
457 浏览 0 评论
776 浏览 0 评论
GMT+8, 2025-2-23 13:50 , Processed in 0.595843 second(s), Total 76, Slave 58 queries .
