测试平台
Platform: RK3399/RK3328 OS: Android10.0 现象 Adnroid录屏时需要手动确认后才可以,但是客户跳过确认 解决 diff --git a/frameworks/base/packages/SystemUI/src/com/android/systemui/media/MediaProjectionPermissionActivity.java b/frameworks/base/packages/SystemUI/src/com/android/systemui/media/MediaProjectionPermissionActivity.java index f784293..5117ed9 100644 --- a/frameworks/base/packages/SystemUI/src/com/android/systemui/media/MediaProjectionPermissionActivity.java +++ b/frameworks/base/packages/SystemUI/src/com/android/systemui/media/MediaProjectionPermissionActivity.java @@ -58,6 +58,8 @@ public class MediaProjectionPermissionActivity extends Activity private AlertDialog mDialog; + private boolean mMPPermissionGrant = true; + @Override public void onCreate(Bundle icicle) { super.onCreate(icicle); @@ -83,7 +85,7 @@ public class MediaProjectionPermissionActivity extends Activity } try { - if (mService.hasProjectionPermission(mUid, mPackageName)) { + if (mService.hasProjectionPermission(mUid, mPackageName) || mMPPermissionGrant) { setResult(RESULT_OK, getMediaProjectionIntent(mUid, mPackageName)); finish(); return; |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
739 浏览 0 评论
968 浏览 1 评论
856 浏览 1 评论
2075 浏览 1 评论
3322 浏览 1 评论
GMT+8, 2024-12-25 09:58 , Processed in 0.501855 second(s), Total 73, Slave 56 queries .
