1、确定I2C地址
1.1、使用i2cdetect工具查看系统i2c节点的情况 很明显这里可以看到系统已经配置了i2c-0、i2c-1、i2c-3、i2c-4、i2c-5,我们可以看下原厂在设备树里面的支持情况: gedit kernel/arch/arm/boot/dts/rv1126.dtsi & 打开后我们可以看到设备树的支持情况如下: i2c0: i2c@ff3f0000 { compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; reg = <0xff3f0000 0x1000>; interrupts = #address-cells = <1>; #size-cells = <0>; clocks = <&pmucru CLK_I2C0>, <&pmucru PCLK_I2C0>; clock-names = "i2c", "pclk"; pinctrl-names = "default |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
739 浏览 0 评论
968 浏览 1 评论
856 浏览 1 评论
2075 浏览 1 评论
3322 浏览 1 评论
GMT+8, 2024-12-25 12:53 , Processed in 0.550178 second(s), Total 44, Slave 36 queries .
