注意
## Ubuntu 20 ## QT/ffplay 硬件解码器工作正常。 ### 注意 X11/Desktop Qt 和 mpv 的硬件视频解码器是基于 gstream 插件的 ### Firefly ffmpeg 来自 firefly source resposity ## dpkg -l |grep firefly # /etc/apt/sources.list root@firefly:~ # cat /proc/version Linux 版本 4.4.194+ (jincheng@jincheng-PC) (local/internal-gitlab/rk3399/firefly: 44a8d8fabe4b94d62ed24e19b7946084a0a5fe29) (gcc 版本 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #3 SMP Thu Sep 9 14:41:07 CST 2021 root@firefly:~# root@firefly:~# cat /etc/^C root@firefly:~# cat /etc/issue Ubuntu 20.04.3 LTS n l firefly@萤火虫:~$ echo $XDG_SESSION_TYPE x11 firefly@firefly:~$ firefly@firefly:~$ xdriinfo libGL error: failed to create dri screen libGL error: failed to load driver: rockchip libGL error: failed to create dri screen libGL error: failed to load driver: rockchip Screen 0: swrast firefly@firefly:~$ tty /dev/pts/3 firefly@firefly:~$ irefly@firefly:~$ glmark2-es2-drm arm_release_ver of this libmali is ‘r18p0-01rel0’, rk_so_ver is ‘4’.arm_release_ver of这个libmali是‘r18p0-01rel0’,rk_so_ver是‘4’。=================================== ==================== glmark2 2021.02 ============================ ============================ OpenGL信息 GL_VENDOR:ARM GL_RENDERER: Mali-T860 GL_VERSION: OpenGL ES 3.2 v1.r18p0-01rel0.5cb5681058e8e076ff89747c20c32578 ================================ ====================== [build] use-vbo=false: FPS: 60 FrameTime: 16.667 ms [build] use-vbo=true: FPS: 60 FrameTime: 16.667 ms [texture] texture-filter=nearest: FPS: 60 FrameTime: 16.667 ms [texture] texture-filter=linear:^C FPS: 60 FrameTime: 16.667 ms ============ ============================================= glmark2 得分:60 === ==================================================== == ## Ubuntu 20 ## QT/ffplay 硬件解码器工作正常。 ### 注意 X11/Desktop Qt 和 mpv 的硬件视频解码器是基于 gstream 插件的 ### Firefly ffmpeg 来自 firefly source resposiity ## dpkg -l |grep firefly # /etc/apt/sources.list |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
678 浏览 0 评论
920 浏览 1 评论
814 浏览 1 评论
2030 浏览 1 评论
3275 浏览 1 评论
GMT+8, 2024-12-24 11:25 , Processed in 0.552701 second(s), Total 74, Slave 56 queries .
