一块板子一份源码二话不说就是怼,南墙不挡头铁。
环境搭建 操作系统 推荐64位Ubuntu,官网 以UltraISO写入U盘,bios设置优先启动进行安装,略。 换源 提高国内下载速度,如USTC。 # 法一: sudo sed -i 's/archive.ubuntu.com/mirrors.ustc.edu.cn/g' /etc/apt/sources.list # 法二: # 直接编辑 /etc/apt/sources.list 文件,在开头添加: # 默认注释了源码镜像以提高 apt update 速度,如有需要可自行取消注释 deb xenial main restricted universe multiverse # deb-src xenial main main restricted universe multiverse deb xenial-updates main restricted universe multiverse # deb-src xenial-updates main restricted universe multiverse deb xenial-backports main restricted universe multiverse # deb-src xenial-backports main restricted universe multiverse deb xenial-security main restricted universe multiverse # deb-src xenial-security main restricted universe multiverse # 预发布软件源,不建议启用 # deb xenial-proposed main restricted universe multiverse # deb-src xenial-proposed main restricted universe multiverse 设置JDK Openjdk,需要另外添加该源。 sudo add-apt-repository ppa:openjdk-r/ppa # 当add-apt-repository不可用,执行sudo apt-get install software-properties-common sudo apt-get update sudo apt-get install openjdk-7-jdk # 6.0用openjdk-7 # sudo apt-get install openjdk-8-jdk # 7.1.1用openjdk-8 安装结束后输入java、javac、java -version验证是否设置完毕,如果出现问题需要追加配置信息: # sudo gedit /etc/profile # 以下内容追加在文件末尾 export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64 export JRE_HOME=${JAVA_HOME}/jre export CLASSPATH=.:${JAVA_HOME}/lib:${JRE_HOME}/lib export PATH=${JAVA_HOME}/bin:$PATH # source /etc/profile # 刷新 环境依赖 编译Android系统,需要依赖以下项目, # Ubuntu14.04,Android6.0 sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev libesd0-dev libwxgtk2.8-dev squashfs-tools build-essential zip curl libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev lib32readline-gplv2-dev gcc-multilib libswitch-perl # Ubuntu14.04,Android7.1 sudo apt-get install git-core gnupg flex bison gperf libsdl1.2-dev libesd0-dev libwxgtk2.8-dev squashfs-tools build-essential zip curl libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev lib32readline-gplv2-dev gcc-multilib libswitch-perl # Ubuntu16.04, 与14.04有所不同,此处只验证对Android6.0编译可用 sudo apt-get install -y git flex bison gperf build-essential libncurses5-dev:i386 sudo apt-get install libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-dev g++-multilib sudo apt-get install tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386 sudo apt-get install dpkg-dev libsdl1.2-dev libesd0-dev sudo apt-get install git-core gnupg flex bison gperf build-essential sudo apt-get install zip curl zlib1g-dev gcc-multilib g++-multilib sudo apt-get install libc6-dev-i386 sudo apt-get install lib32ncurses5-dev x11proto-core-dev libx11-dev sudo apt-get install lib32z-dev ccache sudo apt-get install libgl1-mesa-dev libxml2-utils xsltproc unzip m4 # 通用项,交叉编译工具链 sudo apt-get install gcc-arm-linux-gnueabihf lzop libncurses5-dev libssl1.0.0 libssl-dev 另,可以在 .bashrc文件末尾追加,提高编译效率 echo export USE_CCACHE=1 >> ~/.bashrc 源码与设置 源码压缩包下载 下载地址:百度云盘 # 验证MD5 md5sum /project/Firefly-RK3399_Android6.0_git_20170310.tar.gz # 解压缩 cd ~/project/firefly-rk3399 tar xzvf Firefly-RK3399_Android6.0_git_20170218.tar.gz # 7z x /path/to/Firefly-RK3399_Android7.1.1_git_20170518.7z # 还原代码 git reset --hard 线上源码 # 都开始编译了才发现有线上源码是不是傻... git remote rm origin git remote add gitlab # git remote add gitlab # 更新远程仓库 git pull gitlab Firefly_RK3399:Firefly_RK3399 高速缓存 # 设置编译器高速缓存,提高编译效率 cd ~/workspace/RK3399 prebuilts/misc/linux-x86/ccache/ccache -M 50G 编译进行时 官方编译脚本(发现的太晚…) cd ~/project/firefly-rk3399/ ./FFTools/make.sh -k -j8 # 单独编译kernel ./FFTools/make.sh -u -j8 # 单独编译uboot ./FFTools/make.sh -a -j8 # 单独编译android上层 ./FFTools/make.sh -j8 # 同时编译ubooot、kernel、android 手动编译 cd ~/project/firefly-rk3399/kernel/ # 编译kernel make ARCH=arm64 firefly_defconfig make -j8 ARCH=arm64 rk3399-firefly.img # 编译uboot: make rk3399_box_defconfig make ARCHV=aarch64 -j8 # 编译android: source build/envsetup.sh lunch rk3399_firefly_box-userdebug make -j8 ./mkimage.sh 备注:8为同时编译的线程数,一般google推荐这个数字为2倍的cpu个数再加上2,比如4核,就是10。 # 查看CPU个数 cat /proc/cpuinfo 编译错误记录 记录下编译的注意点和错误。 系统编译失败 error: unsupported reloc 43 碰到报出一串error: unsupported reloc 43,尝试第一次修改。 # mydroid/art/build/Android.common_build.mk,定位到75行 ifneq ($(WITHOUT_HOST_CLANG),true) # 改为 ifeq ($(WITHOUT_HOST_CLANG),false) 经过第一次修改之后发现编译还是报同样的错误,执行下面: cp /usr/bin/ld.gold /prebuilts/gcc/linux-x86/host/x86_64-linux-glibc2.11-4.6/x86_64-linux/bin/ld make update-api make... 中断编译 如果中断后重新编译,最好make clean后再编。 补充记录: (1) make clean 在build/core/main.mk中定义,删除out目录下所有; (2) make clobber 类似make clean; (3) make dataclean 在bulid/core/cleanbuild.mk中定义; (3) make installclean 在bulid/core/cleanbuild.mk中定义; bc not found 编译kernel出现bc not found,[include/generated/timeconst.h] Error 127。 sudo apt-get install bc Communication error with Jack server (52) # Error Building with Jack: out/target/common/obj/JAVA_LIBRARIES/android-support-transition-res_intermediates/classes.jack Communication error with Jack server (52). Try 'jack-diagnose' # Solution find . -name jack-admin export PATH=$PATH:~/proj/firefly-rk3399/prebuilts/sdk/tools jack-admin start-server export directory xxx is not writable # Error Property 'jack.dex.output.dir' (in Options): directory 'out/target/common/obj/JAVA_LIBRARIES/conscrypt_intermediates/jack-rsc' is not writable (required because 'jack.dex.output.container' (defined in Options) is set to 'dir') # Solution edit $HOME/.jack-server/config.properties and set jack.server.max-service=1 file xxx can not be created # Error [ 30% 15013/48677] build out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack FAILED: /bin/bash -c "(mkdir -p out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack.tmpjill.res ) && (unzip -qo prebuilts/sdk/9/android.jar -d out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack.tmpjill.res ) && (find out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack.tmpjill.res -iname "*.class" -delete ) && (JACK_VERSION=3.36.CANDIDATE out/host/linux-x86/bin/jack @build/core/jack-default.args --verbose error -D jack.import.resource.policy=keep-first -D jack.import.type.policy=keep-first -D jack.android.min-api-level=1 --import prebuilts/sdk/9/android.jar --import-resource out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack.tmpjill.res --output-jack out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack ) && (rm -rf out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack.tmpjill.res )" 1 error during configuration. Try --help-properties for help. Property 'jack.library.output.zip' (in Options): file 'out/target/common/obj/JAVA_LIBRARIES/sdk_v9_intermediates/classes.jack' can not be created (required because 'jack.library' (defined in Options) is set to true and 'jack.library.output.container' (defined in Options) is set to 'zip') # Solution export ‘atomic’ file not found # Error frameworks/native/include/binder/Binder.h:20:10: fatal error: 'atomic' file not found #include ^ 1 error generated. # Solution make clean and rebuild. Cannot allocate memory # Error [ 9% 4800/48682] host C++: libart_32 <= art/runtime/verifier/method_verifier.ccninja: fatal: fork: Cannot allocate memory # Solution 解决,调低参数 export export Waiting for unfinished jobs # Error make: *** [out/target/product/rk3399_firefly_box/obj/STATIC_LIBRARIES/libLLVMScalarOpts_intermediates/ADCE.o] Error 1 make: *** Waiting for unfinished jobs.... make: *** [out/target/product/rk3399_firefly_box/obj/STATIC_LIBRARIES/libLLVMObject_intermediates/IRObjectFile.o] Error 1 make: *** [out/target/product/rk3399_firefly_box/obj/STATIC_LIBRARIES/libLLVMARMDisassembler_intermediates/ARMDisassembler.o] Error 1 # Solution 结束编译,clean后重编。 OTA编译失败 # Error No RK Loader for TARGET_DEVICE rk3288 to otapackage package add resource.img to BOOT and RECOVERY No uboot for uboot/uboot.img to otapackage No trust for uboot/trust.img to otapackage No charge for uboot/charge.img to otapackage No parameter for TARGET_DEVICE rk3288 to otapackage Package target files: out/target/product/rk3288/obj/PACKAGING/target_files_intermediates/rk3288-target_files-eng.guochongxin.zip building image from target_files RECOVERY... Traceback (most recent call last): File "./build/tools/releasetools/make_recovery_patch", line 68, in main(sys.argv[1:]) File "./build/tools/releasetools/make_recovery_patch", line 39, in main input_dir, "RECOVERY") File "/home/guochongxin/rk/rk3288_5.1/build/tools/releasetools/common.py", line 411,in GetBootableImage info_dict) File "/home/guochongxin/rk/rk3288_5.1/build/tools/releasetools/common.py", line 365, in BuildBootableImage p4 = Run(sign_cmd) File "/home/guochongxin/rk/rk3288_5.1/build/tools/releasetools/common.py", line 86, in Run return subprocess.Popen(args, kwargs) File "/usr/lib/python2.7/subprocess.py", line 679, in init errread, errwrite) File "/usr/lib/python2.7/subprocess.py", line 1249, in _execute_child raise child_exception OSError: [Errno 2] No such file or directory make: * [out/target/product/rk3288/obj/PACKAGING/target_files_intermediates/rk3288-target_files-eng.guochongxin.zip] Error # Solution drmsigntool没有编译进去, cd build/tools/drmsigntool/ mm -B cd ~/workspace/RK3399 make otapackage 打包固件 编译到打包 source build/envsetup.sh lunch rk3399_** ./FFTools/make.sh -j12 ./mkimge.sh ota make otapackage #[100% 234/234] 在out/target/product/xxxx/生成xxxx.zip本地OTA升级包 # 打包统一固件,rockdev/Image-rk3399_firefly_box/update.img ./FFTools/mkupdate/mkupdate.sh update Windows下打包,不常用 将编译生成的文件拷贝到 AndroidTool 的 rockdevImage 目录中 然后运行 rockdev 目录下的 mkupdate.bat 批处理文件即可创建 update.img 并存放到 rockdevImage 目录里。 OTA升级 # 0. 生成签名 java -Xmx2048m -jar out/host/linux-x86/framework/signapk.jar -w build/target/product/security/testkey.x509.pem build/target/product/security/testkey.pk8 # 1. 打补丁 git apply xxx.patch # 2. 在源码根目录 make installclean source build/envsetup.sh make -j4 source buildenvsetup.sh cd build/tools/drmsigntool/ mm -B # 3. 返回源码根目录 ./mkimage.sh ota make otapackage # 4. OTA升级包位置 # out/target/product/xxxx/xxxx.zip |
1603 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3375 浏览 0 评论
2298 浏览 1 评论
3519 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3791 浏览 1 评论
GMT+8, 2024-9-20 22:57 , Processed in 0.570650 second(s), Total 72, Slave 54 queries .
