一: 下载Android 7.1 code
*百度网盘 链接:https://pan.baidu.com/s/15L9OvFX-06xF0fdkXNTW_A 提取码:voch * 检查文件是否缺失: * md5sum rk3399-firefly-industry-71-20190926.7z.001 * md5sum Firefly-RK3399_Android8.1_git_SDK_20180901.7z.002 * cat Firefly-RK3399_Android8.1_git_SDK_20180901.7z.001.md5sum *cat Firefly-RK3399_Android8.1_git_SDK_20180901.7z.002.md5sum * 解压文件 * # apt-get install p7zip-full * # 7z x Firefly-RK3399_Android8.1_git_SDK_20180901.7z.001 *# git reset --hard * 更新远程仓库 * # git clone https://gitlab.com/TeeFirefly/rk3399-industry-nougat-bundle.git .bundle 二: 搭建编译环境 *安装jdk: sudo apt-get install openjdk-8-jdk java -version *安装编译环境: sudo apt-get update sudo apt-get install git gnupg flex bison gperf libsdl1.2-dev libesd-java libwxgtk3.0-dev squashfs-tools build-essential zip curl libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev lib32readline-dev gcc-multilib libswitch-perl libssl-dev unzip zip 三:编译 四:build error Ensure Jack server is installed and started 解决方案 out/host/linux-x86/bin/jack-admin kill-server out/host/linux-x86/bin/jack-admin start-server 安装jdk的方法 https://blog.csdn.net/sun8112133/article/details/79905401 查看jdk路径 update-java-alternatives -l FAILED: /bin/bash -c "prebuilts/misc/linux-x86/flex/flex-2.5.39 -oout/host/linux-x86/obj/STATIC_LIBRARIES/libsepol_intermediates/cil/src/cil_lexer.c external/selinux/libsepol/cil/src/cil_lexer.l" ———————————————— 版权声明:本文为CSDN博主「__Fang Wei__」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。 原文链接:https://blog.csdn.net/rookie_wei/article/details/87428820 SSL error when connecting to the Jack server. Try 'jack-diagnose' 三:烧入img |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
678 浏览 0 评论
920 浏览 1 评论
814 浏览 1 评论
2030 浏览 1 评论
3275 浏览 1 评论
GMT+8, 2024-12-24 21:12 , Processed in 0.528213 second(s), Total 73, Slave 55 queries .
